Inventor Engineer-To-Order (Read-Only)
Welcome to Autodesk’s Inventor ETO Forums. Share your knowledge, ask questions, and explore popular Inventor ETO topics.
dmdixit
2179 Views, 1 Reply
Error reading from Pipe
Hi
I have web based application using ETO Server 2012 (5.1.0.322).
I have started getting failures which say
System.ServiceModel.CommunicationException: There was an error reading from the pipe: The pipe has been ended. (109, 0x6d). ---> System.IO.IOException: The read operation failed, see inner exception. ---> System.ServiceModel.CommunicationException: There was an error reading from the pipe: The pipe has been ended. (109, 0x6d). ---> System.IO.PipeException: There was an error reading from the pipe: The pipe has been ended. (109, 0x6d). at System.ServiceModel.Channels.PipeConnection.FinishSyncRead(Boolean traceExceptionsAsErrors) at System.ServiceModel.Channels.PipeConnection.Read(Byte[] buffer, Int32 offset, Int32 size, TimeSpan timeout) --- End of inner exception stack trace --- at System.ServiceModel.Channels.PipeConnection.Read(Byte[] buffer, Int32 offset, Int32 size, TimeSpan timeout) at System.ServiceModel.Channels.DelegatingConnection.Read(Byte[] buffer, Int32 offset, Int32 size, TimeSpan timeout) at System.ServiceModel.Channels.ConnectionStream.Read(Byte[] buffer, Int32 offset, Int32 count, TimeSpan timeout) at System.ServiceModel.Channels.ConnectionStream.Read(Byte[] buffer, Int32 offset, Int32 count) at System.Net.FixedSizeReader.ReadPacket(Byte[] buffer, Int32 offset, Int32 count) at System.Net.Security.NegotiateStream.StartFrameHeader(Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.NegotiateStream.StartReading(Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.NegotiateStream.ProcessRead(Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest) --- End of inner exception stack trace --- at System.Net.Security.NegotiateStream.ProcessRead(Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.NegotiateStream.Read(Byte[] buffer, Int32 offset, Int32 count) at System.ServiceModel.Channels.StreamConnection.Read(Byte[] buffer, Int32 offset, Int32 size, TimeSpan timeout) --- End of inner exception stack trace --- Server stack trace: at System.ServiceModel.Channels.StreamConnection.Read(Byte[] buffer, Int32 offset, Int32 size, TimeSpan timeout) at System.ServiceModel.Channels.SessionConnectionReader.Receive(TimeSpan timeout) at System.ServiceModel.Channels.SynchronizedMessageSource.Receive(TimeSpan timeout) at System.ServiceModel.Channels.FramingDuplexSessionChannel.Receive(TimeSpan timeout) at System.ServiceModel.Channels.FramingDuplexSessionChannel.TryReceive(TimeSpan timeout, Message& message) at System.ServiceModel.Dispatcher.DuplexChannelBinder.Request(Message message, TimeSpan timeout) at System.ServiceModel.Channels.ServiceChannel.Call(String action, Boolean oneway, ProxyOperationRuntime operation, Object[] ins, Object[] outs, TimeSpan timeout) at System.ServiceModel.Channels.ServiceChannelProxy.InvokeService(IMethodCallMessage methodCall, ProxyOperationRuntime operation) at System.ServiceModel.Channels.ServiceChannelProxy.Invoke(IMessage message) Exception rethrown at [0]: at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) at Autodesk.Intent.Services.IIntentServices.GetBoolean(String partRefChain, String ruleRefChain) at Autodesk.Intent.Services.IntentServiceWrapper.GetBoolean(String partRefChain, String ruleRefChain) at Autodesk.Intent.Services.IntentServiceWrapper.GetBoolean(String partRefChain, String ruleRefChain) at SyncInvokeGetBoolean(Object , Object[] , Object[] ) at System.ServiceModel.Dispatcher.SyncMethodInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs) at System.ServiceModel.Dispatcher.DispatchOperationRuntime.InvokeBegin(MessageRpc& rpc) at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage5(MessageRpc& rpc) at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage4(MessageRpc& rpc) at System.ServiceModel.Dispatcher.MessageRpc.Process(Boolean isOperationContextSet)
Server stack trace: at System.ServiceModel.Channels.ServiceChannel.HandleReply(ProxyOperationRuntime operation, ProxyRpc& rpc) at System.ServiceModel.Channels.ServiceChannel.Call(String action, Boolean oneway, ProxyOperationRuntime operation, Object[] ins, Object[] outs, TimeSpan timeout) at System.ServiceModel.Channels.ServiceChannelProxy.InvokeService(IMethodCallMessage methodCall, ProxyOperationRuntime operation) at System.ServiceModel.Channels.ServiceChannelProxy.Invoke(IMessage message) Exception rethrown at [0]: at SubmitProject.BtnSubmit_Click(Object sender, EventArgs e) in c:\inetpub\wwwroot\GaylordInVentWebSite\SubmitProject.aspx.cs:line 987 at System.Web.UI.WebControls.Button.RaisePostBackEvent(String eventArgument) at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
Communication state is shown as 'Faulted'
Please let me know if I am doing something wrong here.
regards,
dmdixit
1 REPLY 1
There are multiple reasons a pipe error like this can happen, such as a timeout or a lower level exception that causes the CommunicationObject to become faulted. ETO Server logs exceptions in the Windows Event Log. You can view them on the Intent Services Configurator's Error Log tab, or by looking in the Window Event Viewer under Application\IntentServices.
Another way to help diagnose the underlying cause is to enable WCF logging. You can do this by editing the IntentSessionHost.config file in the ETO Server bin directory and uncommenting this section: (re-comment it out when you are done since it affects performance)
<system.diagnostics>
  <sources>
    <source name="System.ServiceModel"
            switchValue="Information, ActivityTracing"
            propagateActivity="true">
      <listeners>
        <add name="traceListener"
            type="System.Diagnostics.XmlWriterTraceListener"
            initializeData= "c:\log\Traces.svclog" />
      </listeners>
    </source>
  </sources>
</system.diagnostics>
 Then try again and let us know if the Event Log or Traces.svclog file gives you more information.
Scott Anderson
Principal Software Engineer
