I am trying to get a clean install of AutoCad 2013 and Intent 2013. I uninstalled all autocad and Inventor 2012 and installed autocad 2013. Then I installed Autodesk_Inventor_ETO_Series_2013_R2_ADN_English_Win_64bit.part1 and part 2. At install I just selected the ETO.
It created a autocad Intent icon but when I start the program I am getting the message:
Error message: The Menu group INTENT is loaded already.
Are there any instructions about cleaning up the registry or something else I can try?
John
If I try to add folders to the Tools/Options/Intent Design Files Search Path I get a fatal error and it crashes.
So I can run the AutoCad 2013 but can't run the AutoCad 2013 Intent.
John
Followed the instructions at the link below and cleared up my problems.
How to perform a clean uninstall of an Autodesk product
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22100879&linkID=9240617
