Inventor Engineer-To-Order (Read-Only)
Welcome to Autodesk’s Inventor ETO Forums. Share your knowledge, ask questions, and explore popular Inventor ETO topics.
Editing items in a list
3 REPLIES 3
667 Views, 3 Replies
Hi All,
I am tyring to edit a mulitilevel/multiDimensional list but I am getting a compile error.
What I am trying to do is;
   1. to generate a list of parameters for listed children
   2. edit the created list based on a few conditional checks
Now the list is created and is working fine, but when I want to edit an item in the list; I am getting the comlie error.
Here's what my rule looks like:
Rule lstPreStdPanels As List
    Dim panelCounter As Integer
    'loop to create the panel parameters list
    For panelCounter = 1 To intNoStdPanels
        lstPreStdPanels = lstPreStdPanels + {{ _
        ":origin", Point(panelCounter * StdPanelLength,0,0), _
        ":xDirection", Vector(0, -1, 0), _
        ":yDirection", Vector(-1, 0, 0), _
        ":panel_length" , StdPanelLength }}
    Next
    Dim openingCounter As Integer
    'Loop through the opening list to check if need changed length
     For openingCounter = 1 To length ( lstOpeningList )
        If nth (5, nth( openingCounter , lstOpeningList ) ) = "T" Then
                'Determine the target panels
                If GetX(Second(nth(panelCounter,lstPreStdPanels)) >50 Then
                   'nth(8, nth( panelCounter, lstPreStdPanels ) ) = 5
            Next' panel counter
        EndIf' If opening List = T
    Next' openings counter
End Rule
I am getting the error on the commented line.
I could try to place the conditional checks as the list is generated, but I have more that one conditions which are themself in a loop (in contrast to this sample code).
All help is appreciated.
Thanking you,
Wajih
3 REPLIES 3
FarrenYoung
Editing an element of a list is not possible in the intent language as you have shown.  I have worked around this before by creating a replaceItem function which takes a list, an element index, and a newValue and essentially splits the originally list at the index, excluding the item to replace and builds a new list inserting the newValue between the start and end pieces of the two parts of the list.
--Farren
If this post helps, please click the "thumbs up" to give kudos
If this post answers your question, please click "Accept as Solution"
in reply to: FarrenYoung
Could you please post/attach the function/snippet.
Trying to accomplish what I had asked has exhausted: I am out ideas.
A fresh perspective would be a re-boot.
Thanking you,
Wajih
Chris_Rogers
Here is a method that I wrote which replaces an item in a list by index.
Method ReplaceItemInList(inputList As List, indexOfItemToReplace As Integer, newValue As Any) As List
     Dim lowerList As List = {}
     Dim upperList As List = {}
     If indexOfItemToReplace > 1 Then
          lowerList = subList(inputList, 1, indexOfItemToReplace -1)
     If indexOfItemToReplace < length(inputList) Then
          upperList = subList(inputList, indexOfItemToReplace + 1, length(inputList))
     Return lowerlist + {newValue} + upperList
End Method
-Chris Rogers
Inventor Certified Professional
________________________________________________________
If this post helps, please click the "Thumbs up"/"Kudos"
If this post gives the solution, please click "Accept as Solution"
