There are 24 translator addins available with ETO Server; and I don't find a addin for dwg to dxf export in API
Is there is any addin to export dwg to dxf via API?
I have attached screen shots of error message.
Balaji A
Solved by AlexKorzun. Go to Solution.
Hi Balaji,
Unfortunately, the DXF-out addin is not supported for Inventor Servers 2014 and 2015.
Did you try to use the DXF output from Configurator 360? Maybe it will serve you as a workaround?
