I'm trying to deploy my application written in ETO 2015 to a client. I use (like always) the ETO install builder wizard and I run the resulting setup.exe on the client. But when I try to open an ETO assemby, the ETO addin on the client is not loaded and I don't have any ETO functionality.
This procedure has always worked for me in the past, did something changed or did I overlooked something ?
Mark
Hi Mark,
I believe this is an issue that was reported to Autodesk Engineering.
Can you confirm that you are not using OEM?
Wayne
I can confirm that I do not use Inventor OEM, but Inventor Professional. I've installed SP1 on my development PC and generated a new client setup via 'ETO install builder wizard ' but resulted into the same result, intent is still not available on my client PC.
Mark
Hi Pim,
Please log an ADN case and let me know the case number.
Wayne
