I need to allow OEM App users to De-Intentify the final assembly model.
Is this even possible?
You should be able to add a button that calls the Intent API to De-Intentify. Everything we do in the ETO UI is done by calling the Intent API.
There is public interface IHostAPI available in Intent.Inventor.Addin.dll. The interface includes DeIntentify method:
/// Saves all open documents into specified folder. All Intent-related information stored in files is removed.
/// Any error reported as exception
/// </summary>
/// <param name="destinationFolder">Destination directory</param>
/// <param name="overwriteExistingFiles">Overwrite existing files, if True</param>
public void DeIntentify(string destinationFolder, bool overwriteExistingFiles)
You can call this from your command.
