I am using the following code to create a sheet in a drawing:
Child assySheet As :LayoutSheet sheetsToDelete = {"Sheet:1"} sheetName = "System Layout" size = "Custom" customHeight = 841 customWidth = 2362 border = "Border-AU" titleBlockDefinition = "TB-AU" End Child
The problem that I am having is that the height of the drawing is coming out at 558.8 even though I am setting it at 841. This issue is consistently happening on three different computers.
The strange thing is that after the drawing has been generated by ETO, I can go into the code and change the height to 840 and the height properly resizes the height to 840.
Has anybody else seen this quirk and fixed it?
I am able to reproduce this with the Drawing Sample and have logged issue DE481.
So far, I'm not finding an easy workaround.
I see you posted an issue number. Is there a list somewhere that shows known bugs and allows users to see the status of bugs such as the one you just logged?
-Brandon
Unfortunately no. That defect is in a tracking system internal to Autodesk. The closest we come to posting any sort of list would be in the Readme.txt file for each product. The known issues that did not make it into the release are posted there.
