Inventor Engineer-To-Order (Read-Only)
Welcome to Autodesk’s Inventor ETO Forums. Share your knowledge, ask questions, and explore popular Inventor ETO topics.
Creating drawings for similar or different parts used in subassemblies
1 REPLY 1
alundr
520 Views, 1 Reply
These are my two scenarios.
1.  Assembly
1.1  Subassembly1
1.1.1  Part1
1.2  Subassembly2
1.2.1  Part1
1.  Assembly
1.1  Subassembly1
1.1.1  Part1
1.2  Subassembly2
1.2.1  Part2
How do I write my code so that I call for the correct number of drawings for the part?  If I call for the drawings to be made at the subassembly level, I could end up making 2 drawings for the same part.  This does not work for scenario 1 but does work for scenario 2 because the parts are different.  So I will need to call for the drawings to be made from the assembly level.  How do I sort the parts to know if I need to make one or two drawings?
1 REPLY 1
alundr
in reply to: alundr
Got it...
ListOfDrawingParts gives me a list of the unique parts with the 32digit part number.
CenterPlateDrawingList gives me the number of unique parts of the type CenterPlate.
You can see in the image that while there are two divverent center plates, there is a common BottomPan.
Thanks for looking
Parameter Rule ListOfDrawingParts As List
	ListOfDrawingParts = {}
	Dim tempDoc As Any
	Dim tempPN As String
	For x=1 To length(root.children)
		tempDoc = nth(x,root.children)
		tempPN = iv_PropertyGet(tempDoc,"Part Number")
		If find(tempPN, ListOfDrawingParts, key := :second) = NoValue  Then
			ListOfDrawingParts = ListOfDrawingParts + {{nth(x,root.children),tempPN}}
		End If
		If nth(x,root.children).iskindof?(:IvMateConstraint) Or _
			nth(x,root.children).iskindof?(:IvInsertConstraint) Or _
			nth(x,root.children).iskindof?(:IvWorkPlane) Then
		ElseIf nth(x,root.children).iskindof?(:CoilAssembly) Then
			For y=1 To length(nth(x,root.children).children)
				If nth(y,nth(x,root.children).children).iskindof?(:IvMateConstraint) Or _
					nth(y,nth(x,root.children).children).iskindof?(:IvInsertConstraint) Or _
					nth(y,nth(x,root.children).children).iskindof?(:IvWorkPlane) Then
				ElseIf nth(y,nth(x,root.children).children).iskindof?(:IvAssemblyDocument) Then
					tempDoc = nth(y,nth(x,root.children).children)
						ListOfDrawingParts = ListOfDrawingParts + {{nth(y,nth(x,root.children).children),tempPN}}
						For z=1 To length(nth(y,nth(x,root.children).children).children)
							If nth(z,nth(y,nth(x,root.children).children).children).iskindof?(:IvMateConstraint) Or _
								nth(z,nth(y,nth(x,root.children).children).children).iskindof?(:IvInsertConstraint) Or _
								nth(z,nth(y,nth(x,root.children).children).children).iskindof?(:IvWorkPlane) Then
							Else
								tempDoc = nth(z,nth(y,nth(x,root.children).children).children)
									ListOfDrawingParts = ListOfDrawingParts + {{nth(z,nth(y,nth(x,root.children).children).children),tempPN}}
								End If
							End If
						Next
					End If
				Else
					End If
				End If
			Next
		End If
	Next
	ListOfDrawingParts = sort(ListOfDrawingParts,:Ascending, key := :second)
End Rule
Parameter Rule CenterPlateDrawingList As List
	CenterPlateDrawingList = {}
	For x=1 To length(ListOfDrawingParts)
		If subString(second(nth(x,ListOfDrawingParts)),1,11) = "CenterPlate" Then
			CenterPlateDrawingList = CenterPlateDrawingList + {nth(x,ListOfDrawingParts)}
		End If
	Next
End Rule
