Inventor Engineer-To-Order (Read-Only)
Welcome to Autodesk’s Inventor ETO Forums. Share your knowledge, ask questions, and explore popular Inventor ETO topics.
create and close drawings
7 REPLIES 7
Message 1 of 8
998 Views, 7 Replies
I am creating my drawings with ETO.  It correctly creates a drawing file and opens the file.  How do I create the drawing file without opening it?
Tags (1)
7 REPLIES 7
Message 2 of 8
amandamao
I suppose its the default way we currently handle it, will consider for the slient way, not only for this case, I think.
Amanda
Message 3 of 8
in reply to: amandamao
I'll give this a +1.  We would also like to see a silent drawing generation mode.  Our drawing takes considerable time to update, and it would be nice if it could be done in the background, or silently.
Message 4 of 8
AlexKorzun
For just in case: if you need to produce drawings referencing the similar contents, the IvTemplateDrawing might be handy. By Adopting the Inventor drawing file, the new Design with the ExternalReference Parameter in it will be created. As the ExternalReference is supplied, the whole drawing document is updated.
We distribute sample "TemplatedAssembly.iam" that demos the concept.
Thank you,
Alex Korzun
Inventor-Revit Interop / Inventor-Fusion Interop / Inventor ETO
Autodesk, Inc.
Message 5 of 8
ludesroc
in reply to: AlexKorzun
Hi Alex,
Regarding IvTemplateDrawing...Is there a way to ajust the view scale?
Child TheDrawing As :TemplateDrawing
ExternalReference = ThePart.memberPathName
ViewScale = ???
End Child
Ludesroc
Message 6 of 8
AlexKorzun
in reply to: ludesroc
You have to edit the drawing template via Inventor API or manually, to change the view scale and lay out the drawing views.
Next time when Intent uses the IvTemplateDrawing Part that references the template, it will produce the resulting drawing based on these changes.
Thank you,
Alex Korzun
Autodesk, Inc.
Message 7 of 8
ludesroc
Alex,
Actually, I would like the view scale to adjust based on the model size. In this sample (TemplatedAssembly.iam) if you increase or decrease the OuterD value...the views are not size properly.
Ludesroc
Message 8 of 8
AlexKorzun
the C# code below changes the height of thePart and adjusts views scale based on thePart.Height . It is possible to add other part dimensions into consideration.
Please note that more factors you want to control on the Drawing, the most likely you need to use IvDrawingDocument.
The different way to approach the solution is to switch to the template with the "right" view scale
        static void Test(IHostAPI addinModel, Inventor.Application ThisApplication)
            IntentAPI api = Autodesk.Intent.IntentAPI.Instance;
	    Part thePart = api.ActiveRoot["ThePart"];
	    double height = 30.0;
	    thePart.SetRuleValue("height", height);
	    Part theDrawing = api.ActiveRoot["TheDrawing"];
	    string templateFile = theDrawing["TemplateFile"];
	    DrawingDocument templateDrawing = ThisApplication.Documents.Open(templateFile) as DrawingDocument;
	    foreach( DrawingView view in templateDrawing.Sheets[1].DrawingViews)
		if( !view.ScaleFromBase)
			view.Scale = 100/height; // fugde factor. Depends on desired view W/H
	    using( new SilentOperation( ThisApplication))
	    	templateDrawing.Save();
	    	templateDrawing.Close();
	class SilentOperation : IDisposable
		Inventor.Application _App;
		public SilentOperation(Inventor.Application app)
		    _App = app;
		    _App.SilentOperation = true;
		public void Dispose()
		    _App.SilentOperation = false;
 Height = 30:
Height = 100.0;
Thank you,
Alex Korzun
Autodesk, Inc.
