I am trying to create a tapped hole by passing values from Web UI.
Everything goes fine, but when sending value for "threadDesignation"(string), i am getting the following error.
Exception in function iv_createInstanceDocument [Root.BusbarPlate] Unable to update parameters and/or properties for file: D:\TestProject\Member Files\TestProjectPlate.8A93650F31A8EB0037C4FC7900DA98E7.ipt.The failed part has been saved to the file D:\TestProject\Failed Parts\TestProjectPlate.8A93650F31A8EB0037C4FC7900DA98E7.ipt, to allow for diagnosis of the problem. Could not apply Part Features. Error creating parallel thread for hole.
Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
Following are the values we tried to send
3/8-16 UNC
1/4-20 UNC
But when Passing this value in Intent works fine
threadDesignation is in my threaded hole child rule
I don't know if "passing this value in Intent" means in a rule or via the Intent IDE.
But have you opened the file D:\TestProject\Failed Parts\TestProjectPlate.8A93650F31A8EB0037C4FC7900DA98E7.ipt?
That file should have the "Bad" version of the parameter in it, causing it to fail. This can show you what the Web UI is passing to the part that might be different from the regular Intent UI.
Elly
This could be a problem with Excel on a server OS. (Threads use the Threads.xls file). This post seems like a similar issue.
Wayne
