Inventor Engineer-To-Order (Read-Only)
Welcome to Autodesk’s Inventor ETO Forums. Share your knowledge, ask questions, and explore popular Inventor ETO topics.
color partFeatures
6 REPLIES 6
intentdesign
700 Views, 6 Replies
color partFeatures
Within an IvAdoptedPart I drive a hole with the following code:
    Child hole As :IvPartHoleFeature
        diameter=10
        cboreDiameter=15
        cboreDepth=12
        face="oben"
        edge1="links_oben"
        edge2="vorne_oben"
        distance1=50
        distance2=120
        biasPoint="Ursprung"
        throughAllType=:ThroughAll
        extentDirection=:positive
    End Child
Now I would like to change the color of the hole feature:
    Rule TestColor As Boolean
        Dim InventorComponent As Any = gethostobject(Me).definition.document
        Dim NewRenderStyleObject As Any = InventorComponent.RenderStyles.get_Item("Red")
        Dim oPartFeature As Any = GetHostObject(hole)
        oPartFeature.SetRenderStyle(StyleSourceTypeEnum.kOverrideRenderStyle, NewRenderStyleObject)
        Return True
    End Rule
Changing the color does'nt work. What's wrong?
I'm working with Inventor ETO 2014.
Dieter
6 REPLIES 6
Lesoux
in reply to: intentdesign
Why you didn't try to create hole in factory file and suppress/unsuppress feature if necessary?
Win10 x64
Xeon E5-1630
32 Gb RAM
Quadro K5200
Inventor 2020.3.4, Build 373
AlexKorzun
in reply to: Lesoux
I've added the Inventor namespace into enumeration, and "it works".
' Written by Intent
Design aaa : ETO_SamplesRoot PartHole_Part01
    Child simpleLinearHole As :IvPartHoleFeature
        face = "TopFace"
        edge1 = "TopFrontEdge"
        edge2 = "TopLeftEdge"
        distance1 = 11
        distance2 = 12
        biasPoint = "v001"
        extentDirection = :Positive
        diameter = 10
        cboreDiameter = 15
        cboredepth=12
        throughAllType = :throughAll
    End Child
 Rule TestColor As Any
        Dim oPartFeature As Any = GetHostObject(simpleLinearHole)
        oPartFeature.SetRenderStyle(Inventor.StyleSourceTypeEnum.kOverrideRenderStyle, NewRenderStyleObject)
        Return oPartFeature
 End Rule
End Design
Thank you,
Alex Korzun
Inventor-Revit Interop / Inventor-Fusion Interop / Inventor ETO
Autodesk, Inc.
intentdesign
in reply to: AlexKorzun
Hi Alex
That works fine now.
Can you please tell me how to add a parameter named "color" to the IvPartHoleFeature  design that colors the feature directly?
Dieter
AlexKorzun
Hi Dieter,
Though it might change in future, please try overriding the modelself Rule for the part with the hole chile, injecting the code:
'  Written by Intent
    'Add the drilled hole feature
    Child simpleLinearHole As :PartHoleFeaturewithcolor
        'drilledType = :Drilled
        face = "TopFace"
        distance1 = 11
        distance2 = 12
        biasPoint = "v001"
        diameter = 10
        cboreDiameter = 15
        cboredepth=12
    End Child
    < %%category(""), _
        %%choices("%%colorChoices"), _
        %%PEAllowOther?("True"), _
        %%evalChoices("True") > _
  Parameter Rule FeatureColor As String = "red"
  Rule modelSelf As List
    memberPathname
    Dim ret As List =  { %%updateSelf }
     Dim InventorComponent As Any = GetHostObject( Me).definition.document
     Dim NewRenderStyleObject As Any = InventorComponent.RenderStyles.get_Item( FeatureColor)
    Dim oPartFeature As Any = Gethostobject(simpleLinearHole)
    Return ret
  End Rule
Thank you,
Alex Korzun
Autodesk, Inc.
intentdesign
Thanks Alex, that works.
Dieter
AlexKorzun
Hi Dieter,
The only remaining thing is to mix the FeatureColor into part's signature, if it is required.
The simplest is to create a dummy string parameter, include it into %%paramList.
OR
modify iProperties Rule to containt the similar to:
  Parameter Rule iProperties As List = {{"FC", FeatureColor}}
Thank you,
Alex Korzun
Autodesk, Inc.
