When i added the choices for color as shown in image1.
The parameter dropdown is listed as in image 2.
Can any one guide me in providing values for choices.
Chockalingam
Solved by AlexKorzun. Go to Solution.
I haven't looked into this in detail, but you can create a rule to build the choice list, and use %%EvalChoices to tell the system that the %%Choices string should be treated as a rule name to be evaluated instead of parsed as a list. That way, you have more control over the list.
Hi
You can specify the comma separator in the %%ChoicesDelimiter annotation.
<%%Choices("C1 color,C2 color,C3 color"), %%ChoicesDelimiter(",")> _
Parameter Rule theColorOld As String = "C1 color"
The alternative way to deal with your problem is something similar to:
<%%Choices("%%availableColors"), %%EvalChoices("True")> _
Parameter Rule theColor As String = "C1 color"
Rule %%availableColors As List = {"C1 color", "C2 color", "C3 color"}
