Inventor Engineer-to-Order
Distinguished Contributor
5 Kudos
Post 1 of 4
Client Graphic
179 Views, 3 Replies
11-01-2012 09:43 AM
I'm trying to add a simple text (client graphic) on screen...Can somebody point me in the right direction???
Child testCG As :CGText
Text = "Test"
AnchorPosition = Point(0,0,0)
AnchorCorner = :Left
visible? = True
position = Point(5,5,0)
Scalable? = True
Bold? = False
Italic? = False
Font = %%InventorApplication.GeneralOptions.TextAppearance
FontSize = %%InventorApplication.GeneralOptions.TextSize
HorizontalAlignment = :Left
VerticalAlignment = :BaseLine
End Child
I get :
Exception in function cg_drawText
Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
Luc
Ludesroc
As Jon mentioned, there seems to be a defect in CGText VerticalAlignment.  If it is set to :BaseLine it will fail.  But if you set it to one of the other choices (Middle, Upper, Lower) it seems to be ok.  I will look into this further and file the issue in our tracking system.
Also, the choices for AnchorCorner are: None, TopLeft, TopRight, BottomLeft, BottomRight.  You have it set to :Left, which is not a valid choice.
Child TheText As :CGText, Quantity = Quantity2D
Text = "Test"
AnchorCorner = :None
visible? = True
Scalable? = True
Bold? = False
Italic? = False
VerticalAlignment = :Lower
End Child
-Casey
Works great!
Thanks Casey!
Board Manager
32 Kudos
Post 2 of 4
Re: Client Graphic
11-01-2012 05:27 PM in reply to: ludesroc
Hi --
This is under investigation ... apparently there are some defects in this area ... try different values for :VerticalAlignment ... more information tomorrow.
Jon Balgley
Autodesk Configurator 360 / Inventor ETO team
Employee
0 Kudos
Post 3 of 4
Re: Client Graphic
11-02-2012 09:33 AM in reply to: ludesroc
	Text = "Test"
        visible? = True
        Scalable? = True
        Bold? = False
        Italic? = False
	End Child
-Casey
5 Kudos
Post 4 of 4
Re: Client Graphic
11-02-2012 10:27 AM in reply to: Casey.Motherway
Works great!
Thanks Casey!
Ludesroc
Manufacturing Community
