Inventor Engineer-To-Order (Read-Only)
Welcome to Autodesk’s Inventor ETO Forums. Share your knowledge, ask questions, and explore popular Inventor ETO topics.
Client Endpoint for ETO Server
1 REPLY 1
ludesroc
481 Views, 1 Reply
I'm trying to run the UI Tools Web Demo and get the following error (see attached picture)...any idea?
Ludesroc
1 REPLY 1
colin.mccoy
in reply to: ludesroc
Hi Ludesroc,
It's not really enough information for me to know what's wrong but I'll throw some ideas at you.
Note: There's another thread with almost exactly the same name (Client Endpoints for ETO server) maybe it has the answer.
I assume you are talking about this sample. After you did Step 2, did you try testing the connection using the "Test Application Services" button in Inventor ETO Server Configurator?
Have you made any configuration changes on the ETO Server or just using the default configuration?
Not much more I can guess without more information. Seems like your ETO Server isn't running on the localhost or it's not using the default configuration.
-Colin
