The P/N colum in a IvPartsList shows the name of the file in the member files folder.
example
floorConcrete.33F290E7057977617DD80F563AC1D26B
I would like to override this with someting that matches our naming convention.
Has anyone come up with a way to do this and if so, how did you do it?
Solved by Chris.Palmatier. Go to Solution.
Hi Tom,
Inventor uses the file name for the part number iProperty. You can set the part number by overriding the iProperties rule in your adopted parts or assemblies, like this:
Rule iProperties As List = {{"Part Number", PartNumber}}
In this case I have a PartNumber rule that builds the part number based on the input parameters of my part.
You can set other iProperties here as well, just add list pairs with the iproperty name and the value.
