Inventor Engineer-to-Order
Lesoux
Message 1 of 5 (367 Views)
Change text color through <StyleOverride>
367 Views, 4 Replies
02-01-2013 07:57 AM
How can I change text color using <StyleOverride>?
Thanks in advance.
Win7 x64
Xeon X5647
24 Gb RAM
Quadro FX 6000
Inventor 2013
ETO 6.1, Build 140.
Employee
AlexKorzun
Message 2 of 5 (351 Views)
Re: Change text color through <StyleOverride>
02-04-2013 07:32 AM in reply to: Lesoux
You did not mention the type of the Inventor object you wanted to apply the Color to.
If the object is under Intent control, try the following:
1. Call GetHostObject()  to step from Intent Part to Inventor object
2. Use the .Color setter on that object.
Thank you,
Alex Korzun
Autodesk Configurator 360 / Inventor ETO team
Lesoux
Message 3 of 5 (347 Views)
02-04-2013 07:48 AM in reply to: AlexKorzun
I'm talking about standard design as :IvGeneralNote.
Win7 x64
Xeon X5647
24 Gb RAM
Quadro FX 6000
Inventor 2013
ETO 6.1, Build 140.
FarrenYoung
Message 4 of 5 (340 Views)
02-04-2013 09:05 AM in reply to: Lesoux
I don't believe this is possible via StyleOverride
Looking at the Inventor API help there is a list of the options that are available via StyleOverride
mk:@MSITStore:C:\Users\farren.young\Desktop\Inventor%202013%20API.chm::/HTML/FormattedTextTags_Overview.htm
Style Override <StyleOverride>
The StyleOverride tag defines all text style information. The various style options are defined within the tag using attributes. These attributes are described below.
Font – Sets which font to use. The input to this attribute is the name of the font.
FontSize – Sets the size of the font. The input to this attribute is the size in centimeters.
Bold – Allows you to turn bolding on or off. The input to this attribute is the String "True" or "False".
Italic – Allows you to turn italics on or off. The input to this attribute is the String "True" or "False".
Underline – Allows you to turn underlining on or off. The input to this attribute is the String "True" or "False".
As Alex mentioned, you will need to override the color property of your object.
To get the color you have to create it using the inventor application transientobjects class.
gethostobject(me).set_color(%%inventorapplication.transientobjects.createcolor(0, 255, 0)) 'RGB value
--Farren
If this post helps, please click the "thumbs up" to give kudos
If this post answers your question, please click "Accept as Solution"
Lesoux
Message 5 of 5 (335 Views)
02-04-2013 09:38 AM in reply to: FarrenYoung
I found best way, I think so.
Just use Style for Note Text.
Win7 x64
Xeon X5647
24 Gb RAM
Quadro FX 6000
Inventor 2013
ETO 6.1, Build 140.
Manufacturing Community
