Inventor Engineer-To-Order (Read-Only)
Welcome to Autodesk’s Inventor ETO Forums. Share your knowledge, ask questions, and explore popular Inventor ETO topics.
Cannot Save Design (unable to parse) with Rule value containing word Select
2 REPLIES 2
FarrenYoung
408 Views, 2 Replies
I am trying to do the following in 4.3.523
	Rule blah As Any = System.Environment.UserName()
	Rule blah2 As Any = System.Environment.Select()
blah is OK.
blah2 is throwing a compile error and will not save.  This is happening in both designs and functions.
--Farren
If this post helps, please click the "thumbs up" to give kudos
If this post answers your question, please click "Accept as Solution"
2 REPLIES 2
Farren, I have reproduced this in the latest build of ETO 2012 and logged the issue as INT-1451.
Just for grins I tried working around it using EvaluateString() to get out of Design Editor (as it has it's own error checking), but it still failed to parse when I evaluated the rule. I don't have a workaround at this point.
Chris Palmatier
Customer Success Engineer
Inventor Engineer-to-Order
Farren,
We just closed this As Designed. Select is a keyword in Intent language and VB, for Select Case. You'll have to use another name for your method.
Chris Palmatier
