We think about updating to ETO 2013 and are not sure what will be possible and what not .
I surged for the key words "call I logic form" but only found a solution to do this via the API.
Now there is no hit to do this within ETO itself for a complete ILogic Assembly . I know this
might seem a bit odd but is it possible to Adopt a complete Assembly and use the ILogic
functionality of this Assembly as well as the form which is part of the assembly in ETO?
So far I managed to Adopt it as ILogic Assembly but the question now is how to go further
and trigger the ILogic UI Form and share Parameters in both directions.
We found out that parameters I change in the Ilogic form are not consequently afterwards
in the parameter listing of the Intent model with the same value.
Timo
