Inventor Engineer-To-Order (Read-Only)
Welcome to Autodesk’s Inventor ETO Forums. Share your knowledge, ask questions, and explore popular Inventor ETO topics.
rabraham
270 Views, 1 Reply
BOMTables
I started a BOMTables and selected piping accordingly,  When it displayed the table in placed each component in it own row with a quantity of 1, such that I had 4 rows of 14" LR Elbows each with a quantity of 1 rather than 1 row with a quantity of 4.
How do we reduce the size of the table as you can imagine in is very large?
1 REPLY 1
Chris_Rogers
in reply to: rabraham
By the sounds of it, you have 4 different elbows.  This means that there are 4 different member files for these parts.
If all 4 parts are "physically" the same and you want them to use the same member file, then you will need to check to properties and parameters to make sure that they are not different.
-Chris Rogers
Inventor Certified Professional
________________________________________________________
If this post helps, please click the "Thumbs up"/"Kudos"
If this post gives the solution, please click "Accept as Solution"
