Inventor Engineer-To-Order (Read-Only)
Welcome to Autodesk’s Inventor ETO Forums. Share your knowledge, ask questions, and explore popular Inventor ETO topics.
Balloons using Workpoints Error
2 REPLIES 2
323 Views, 2 Replies
Hi All. I am trying to attach balloons to a drawing by using workpoints. In the Automation Help file under entity1 it states that it should use a face, edge, vertex, work point, or work axis normal to view. When I try to use a workpoint with a balloon, I have a error box that states: "Balloons can be created on Face or Edge objects only." Any ideas would be appreciated. Thanks.
2 REPLIES 2
glibardi
There are known issues with Balloons and Workpoints. We are not sure if they are a result of a problem in Inventor or Intent. If you could send us a small example that will allow us to reproduce the problem it would help us determine where the problem lies and move toward a solution. Please send the example to Intent.Support@autodesk.com.
Sincerely,
-gene
I'm not sure if you ever got a test case for this, but do you plan to support this in a future Intent release?
