Inventor Engineer-To-Order (Read-Only)
Welcome to Autodesk’s Inventor ETO Forums. Share your knowledge, ask questions, and explore popular Inventor ETO topics.
Add Holes in a Pipe
1 REPLY 1
alundr
977 Views, 1 Reply
Add Holes in a Pipe
I am trying to add an unknown number of holes at random locations up and down a pipe.  Because of the geometry of the pipe, I cannot simply use the Part Hole Feature.  I'm trying to use the Part Extrude Feature and I'm lost as to how it actually works.
In the assembly design I have
Child pipe_1 as :pipe
End Child
In the pipe design I have:
Child Hole As :IvPartExtrudeFeature
    distance = 2
    operation = :cut
    extentDirection = :Positive
    sketchPart = pipe_1
    sketchName = "Sketch7"
    face = "XY Plane"
    origin = "Center Point"
    xAxis = "X Axis"
End Child
In the Sketch7 I have a circle drawn in space without any reference lines crossing through the circle.
I'm getting the error "No such rule 'pipe_1' (parameter) "
I'm not sure what I'm doing wrong.
Is there a better way to add the holes to my pipe?
Andrew
CAD Drafter
1 REPLY 1
alundr
in reply to: alundr
OK.  sketchPart cannot reference the part I am trying to cut a hole in.  Therefore, I needed to create an .ipt file with a sketch of the profile that I wanted to cut out.   my code now looks like this :
Child HoleSketch As :HoleSketch
visible? = False
End Child
distance = 10
operation = :Cut
extentDirection = :positive
sketchPart = HoleSketch_1
sketchName = "Sketch1"
face = "XY Plane"
xAxis = "Y Axis"
End Child
good luck
- Andrew -
