Inventor Engineer-To-Order (Read-Only)
Welcome to Autodesk’s Inventor ETO Forums. Share your knowledge, ask questions, and explore popular Inventor ETO topics.
0xc0000142 - Application Error
1 REPLY 1
citlalli.kuroda_95
465 Views, 1 Reply
Installed Autodesk Inventor on Windows 8, it won't open. The rest of the applications downloaded at the time, work alright.
What should I do?
Tags (2)
1 REPLY 1
If you are running Windows 8.1 then the link below should help. Note that you are completely out of luck at the moment if you need Inventor OEM.
http://forums.autodesk.com/t5/Inventor-General/Inventor-2014-Error-0xC0000142-on-Windows-8/td-p/4354...
Matt
