Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
WriteDataToFile ouputs Incorrect Drawing Sheet Titles while writing to DWF.
1 REPLY 1
384 Views, 1 Reply
I created a Multisheet drawing file.(.idw)
While the file to DWF format with WriteDataToFile, the Title Block shows wrong Sheet number.
For a 5 Sheet drawing, the output DWF files contain following Titles:
1 of 2
2 of 3
3 of 4
4 of 5
5 of 5
Whereas expected titles should be:
1 of 5
2 of 5
3 of 5
4 of 5
5 of 5
Interestingly, if I create a multisheet Drawing and Activate all sheets one by one before saving it.
The DWF files outputted show correct Titles.
Hence in the first case, I used Activate() on all sheets before writing them with WriteDataToFile. But could not get correct Titles.
Seems like a issue with WriteDataToFile()
1 REPLY 1
xiaodong_liang
I maybe missed something, but it looks only Sheet has DataIO, which means you have to output them to DWF one by one. But it looks you output them in one DWF? Could you share your code?
In addition, if this is really a problem, I'd suggest you give it a try with TranslatorAddin of DWF, which maybe work as you expected.
by the way, this is the code I am using with WriteDataToFile
Sub xxx()
    Dim oDoc As DrawingDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oSheet As Sheet
    Dim i As Integer
    i = 1
    For Each oSheet In oDoc.Sheets
        Dim oDataIO As DataIO
        Set oDataIO = oSheet.DataIO
        Dim Formats() As String
        Dim StorageTypes() As StorageTypeEnum
        oDataIO.GetOutputFormats Formats, StorageTypes
        Dim FullFileName As String
        FullFileName = oDoc.FullFileName
        Dim NewFileName As String
        Dim pos As Integer
        'set the file name
        pos = InStrRev(FullFileName, ".")
        NewFileName = Left(FullFileName, pos - 1)
        NewFileName = NewFileName & "_" & i & ".dwf"
        oDataIO.WriteDataToFile "DWF", NewFileName
        i = i + 1
    Next
End Sub
