Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
WorkPoint @ Intersecting Axis and Face
4 REPLIES 4
Genicee
623 Views, 4 Replies
Using API is there a way to add a WorkPoint where an Axis and a Part Face Intersect?
I need this to be able to create a WorkPlane normal to the surface of the part at that location.
4 REPLIES 4
xiaodong_liang
in reply to: Genicee
Genicee
in reply to: xiaodong_liang
I think that will give me a good starting point, but I need that point tied to the axis and face. There has to be something out, because through the UI I with the point command select the axis and part surface to create the point needed to then place my workplane. I quickly did the example in your blog and when I move the axis the work plance does not follow, maybe there is something I am missing.
When I get more time I will play around with it again. Thank you for helping me out. You have given me a few more idea. Smiley Happy
ekinsb
I think this might be what you're looking for.  The other code does the calculation but it doesn't create the point in a way that it's associated to the geometry.
Public Sub AddWorkPointAtIntersection()
    Dim fc As face
    Set fc = ThisApplication.CommandManager.Pick(kPartFaceFilter, "Select a face.")
    Dim axis As WorkAxis
    Set axis = ThisApplication.CommandManager.Pick(kWorkAxisFilter, "Select a work axis.")
    Dim partDef As PartComponentDefinition
    Set partDef = axis.Parent
    Dim wp As WorkPoint
    Set wp = partDef.WorkPoints.AddByCurveAndEntity(axis, fc)
End Sub
Brian Ekins
Inventor and Fusion 360 API Expert
Mod the Machine blog
Genicee
in reply to: ekinsb
Wonderful!!!
That is exactly what I would looking for.  I look in the API help for while. I am sure I just glanced over it. Or misundertood the objective of the method.
Thanks again guys!
