Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Workplane visibility within clientfeature
6 REPLIES 6
tneff2
442 Views, 6 Replies
Is there anyway to completely hide a workplane that is contained within a clientfeature?
The attached part shows this when you hover over the client feature in the browser. I have the visibility of the plane turned off but it still shows up when the clientfeature is pre-selected.
Thanks for your help.
-Thomas
Tags (1)
6 REPLIES 6
philippe.leefsma
in reply to: tneff2
Try creating the workplane as construction: use argument Construction = True when you create the workplane.
This, of course, only applies if you are creating the workplane through API.
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
tneff2
in reply to: philippe.leefsma
That did the trick! Is that what that argument is for? What are the other uses of contruction work features?
-Thomas
philippe.leefsma
in reply to: tneff2
Construction workfeatures can only be accessed through the API, they are completely hidden from the UI, for any reason you may think of.
Philippe.
Philippe Leefsma
tneff2
Can construction work features be projected?
philippe.leefsma
in reply to: tneff2
You would need to give a try 🙂 I've never tried it myself...
Philippe Leefsma
tneff2
Sounds good it was just something I thought of on my way to work today. Thanks for all your help.
