I have written a routine to count the holes in a part. It generates accurate counts, but it is incredibly slow - I can't figure out why. Also, if I don't have the part checked out, it asks me if I want to check it out - I also cannot figure this out, since I am not modifying the document in any way.
It seems that the slow down and the "dirtying" occur at about the same place - on the "Continue For" lines in ProcessPattern. Any ideas on either my speed issue or the dirtying issue?
I removed some code to clean up what needs to be shown here - consider the ProcessPart() method as the main function.
Public Class RivetCounter Private counts As New Hashtable Private Sub AddCount(ByVal diameter As Double, ByVal number As Integer) If counts.ContainsKey(diameter) Then counts(diameter) = CType(counts(diameter), Integer) + number Else counts(diameter) = number End If End Sub Private Sub ProcessPart(ByRef part As Inventor.PartDocument, ByVal quantity As Integer) Dim hole As Inventor.HoleFeature For Each hole In part.ComponentDefinition.Features.HoleFeatures ProcessHoleFeature(hole, quantity) Next hole Dim rectPat As Inventor.RectangularPatternFeature For Each rectPat In part.ComponentDefinition.Features.RectangularPatternFeatures ProcessPattern(rectPat.ParentFeatures, quantity * rectPat.PatternElements.Count, rectPat.ConsumeInputs) Next rectPat Dim circPat As Inventor.CircularPatternFeature For Each circPat In part.ComponentDefinition.Features.CircularPatternFeatures ProcessPattern(circPat.ParentFeatures, quantity * circPat.PatternElements.Count, circPat.ConsumeInputs) Next circPat End Sub Private Sub ProcessHoleFeature(ByRef hole As Inventor.HoleFeature, ByVal quantity As Integer) ' Apparently Inventor uses cm as internal units AddCount(hole.HoleDiameter.ModelValue / 2.54, quantity * hole.HoleCenterPoints.Count) End Sub Private Sub ProcessPattern(ByRef features As Inventor.ObjectCollection, ByVal quantity As Integer, ByVal consumeInputs As Boolean) Dim i As Integer For i = 1 To features.Count ' Try to process the feature as each of the types we are interested in ' On failures, continue trying the next type of feature ' On success, continue with the next feature object ' HoleFeature Try Dim hole As Inventor.HoleFeature = CType(features(i), Inventor.HoleFeature) If consumeInputs Then ProcessHoleFeature(hole, quantity) Else ProcessHoleFeature(hole, quantity - 1) End If Continue For Catch ex As Exception ' Not a hole End Try ' RectangularPatternFeature Try Dim rectPat As Inventor.RectangularPatternFeature = CType(features(i), Inventor.RectangularPatternFeature) If consumeInputs Then ProcessPattern(rectPat.ParentFeatures, quantity * rectPat.PatternElements.Count, rectPat.ConsumeInputs) Else ProcessPattern(rectPat.ParentFeatures, quantity * (rectPat.PatternElements.Count - 1), rectPat.ConsumeInputs) End If Continue For Catch ex As Exception ' Not a rectangular pattern End Try ' CircularPatternFeature Try Dim circPat As Inventor.CircularPatternFeature = CType(features(i), Inventor.CircularPatternFeature) If consumeInputs Then ProcessPattern(circPat.ParentFeatures, quantity * circPat.PatternElements.Count, circPat.ConsumeInputs) Else ProcessPattern(circPat.ParentFeatures, quantity * (circPat.PatternElements.Count - 1), circPat.ConsumeInputs) End If Continue For Catch ex As Exception ' Not a circular pattern End Try Next i End Sub End Class
Thanks for your help!
-Kerry
Solved by ekinsb. Go to Solution.
Wow, this was a tricky one to find. Change your declaration of
to
Private Sub ProcessPattern(ByVal features As Inventor.ObjectCollection, ByVal quantity As Integer, ByVal consumeInputs As Boolean)
It was reassigning the set of parent features for the pattern every time the sub returned.
