Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Why does label and textbox not show in dockablewindow form
2 REPLIES 2
kbo
365 Views, 2 Replies
I try to create a dockable windows form with a label and a textbox, the dockable window shows fine but the label and the textbox on the form loadet i in the dockable window does not show? what am i doing wrong. i Attached the hole program in a zip file. Please help
This program is an inv 2014 addin.
regards kent boettger
2 REPLIES 2
kbo
in reply to: kbo
Okay Forget it found the solution on the net otherwhere,
if somone is interested here it is.
        Public Shared Sub CreateDockableWindow(app As Inventor.Application)
            Dim uiMan As UserInterfaceManager = app.UserInterfaceManager
            Dim dockableWin As Inventor.DockableWindow = uiMan.DockableWindows.Add(Guid.NewGuid().ToString(), "KB_DockableWindow1", "KB - DockableWindow #1")
            dockableWin.AddChild(CreateChildDialog())
            dockableWin.DisabledDockingStates = Inventor.DockingStateEnum.kDockTop + Inventor.DockingStateEnum.kDockBottom
            dockableWin.DockingState = DockingStateEnum.kDockLeft
            dockableWin.ShowVisibilityCheckBox = True
            dockableWin.ShowTitleBar = True
            dockableWin.SetMinimumSize(100, 100)
            dockableWin.Visible = True
        End Sub
        Public Shared Function CreateChildDialog() As Long
            Dim dc As New Form1()
            '   dc.Text = "Child Dialog"
            '   dc.HelpButton = InlineAssignHelper(dc.MinimizeBox, InlineAssignHelper(dc.MaximizeBox, False))
            '   dc.ShowIcon = InlineAssignHelper(dc.ShowInTaskbar, False)
            '    dc.TopMost = True
            '    dc.Height = 100
            '    dc.Width = 300
            '   dc.MinimumSize = New Size(dc.Width, dc.Height)
            ' Dim margin As Integer = 5
            'Dim size As Size = dc.ClientSize
            'Dim tb As New System.Windows.Forms.TextBox()
            '   tb.TextAlign = HorizontalAlignment.Right
            '    tb.Height = 20
            '  tb.Width = size.Width - 2 * margin
            '   tb.Location = New System.Drawing.Point(margin, margin)
            '   tb.Anchor = AnchorStyles.Top Or AnchorStyles.Left Or AnchorStyles.Right
            '   dc.Controls.Add(tb)
            dc.Show()
            Return dc.Handle.ToInt64()
        End Function
 regards. Kent boettger
GeorgK
in reply to: kbo
Hello Kent,
please could you provide a complete sample and attach the zip-file?
Thank you very much
Georg
