Option Explicit Dim blFeatChk As Boolean Dim oWorkSurfs As WorkSurfaces Dim oSurfBody As SurfaceBody Dim oSurfBodies As SurfaceBodies Dim oCompDef As ComponentDefinition Dim oPartCompDef As PartComponentDefinition Dim oPartDoc As PartDocument Dim oSplitFeat As SplitFeature Public Sub SplitAllFaces() Dim oInt As WorkSurface Dim oCaut As WorkSurface Set oPartDoc = ThisApplication.ActiveDocument Set oPartCompDef = oPartDoc.ComponentDefinition Set oSurfBodies = oPartCompDef.SurfaceBodies Set oWorkSurfs = oPartCompDef.WorkSurfaces Set oCaut = oWorkSurfs.Item("Srf1") Set oInt = oWorkSurfs.Item("Srf2") Dim oRS As RenderStyles Set oRS = oPartDoc.RenderStyles Dim oRSAL_Flat As RenderStyle Set oRSAL_Flat = oPartDoc.RenderStyles.Item("Aluminum - Flat") Dim oRSRed As RenderStyle Set oRSRed = oPartDoc.RenderStyles.Item("RED") Dim oRSBlue As RenderStyle Set oRSBlue = oPartDoc.RenderStyles.Item("Blue") Call SplitAllSolids(oCaut, oRSAL_Flat, oRSBlue) Call SplitAllSolids(oInt, oRSBlue, oRSRed) ' For Each oSurfBody In oSurfBodies ' lngBodyChk = 0 ' blFeatChk = True ' Set oSplitFeat = oPartCompDef.Features.SplitFeatures.SplitBody(oInt, oSurfBody) ' ' If blFeatChk Then ' Set oCreatedSurfBodies = oSplitFeat.SurfaceBodies ' For Each oCreatedSurfBody In oCreatedSurfBodies ' If lngBodyChk = 0 Then ' Call oCreatedSurfBody.SetRenderStyle(kOverrideRenderStyle, oRSRed) ' lngBodyChk = 1 ' Else ' Call oCreatedSurfBody.SetRenderStyle(kOverrideRenderStyle, oRSBlue) ' End If ' Next oCreatedSurfBody ' End If ' ' Next oSurfBody End Sub Public Sub SplitAllSolids(oWorkSurf As WorkSurface, oColorIn As RenderStyle, oColorOut As RenderStyle) On Error GoTo err_SplitAllFaces Dim lngBodyChk As Long Dim oCreatedSurfBodies As SurfaceBodies Dim oCreatedSurfBody As SurfaceBody For Each oSurfBody In oSurfBodies lngBodyChk = 0 blFeatChk = True Set oSplitFeat = oPartCompDef.Features.SplitFeatures.SplitBody(oWorkSurf, oSurfBody) If blFeatChk Then Set oCreatedSurfBodies = oSplitFeat.SurfaceBodies For Each oCreatedSurfBody In oCreatedSurfBodies If lngBodyChk = 0 Then Call oCreatedSurfBody.SetRenderStyle(kOverrideRenderStyle, oColorIn) lngBodyChk = 1 Else Call oCreatedSurfBody.SetRenderStyle(kOverrideRenderStyle, oColorOut) End If Next oCreatedSurfBody End If Next oSurfBody end_SplitAllFaces: Exit Sub err_SplitAllFaces: Select Case Err.Number Case -2147467259 'Place holder for no split surface blFeatChk = False Resume Next Case Else MsgBox ("Error ") Resume end_SplitAllFaces End Select End Sub
So for some reason and I'm not sure why the for each loop will have all the surface bodies and then sometimes not, giving me an error number 5. Anyone know why?
I'm not allowed to post the model but all I'm trying for testing purpose is an array of boxes 15x100, each a seperate solid. I have 2 surfaces that extrude through the boxes. I'm trying to have grey, blue, and then red for each zone. The code will work part way and then give an error. Each time it's the for loop for surface bodies. Sometimes the next surface body will register the next surface body and other times it won't. I can't figure out why.
When do you observe it working? Do you open the part and perform the api? Do you run it again after the api?
I'll open the part, run the api. Then if I delete the splits and start over I'll get part way through and then crash.
