Which rxinventor.tlb to use?
1 REPLY 1
oransen
784 Views, 1 Reply
I'm using SimpleExe.Exe to start investigating C++ inventor programming.
The project as is does not work because it does not find rxinventor.tlb.
That can be fixed by adding the correct path to the tlb file in my solution directory settings.
But which path? There are two:
C:\Program Files\Autodesk\Inventor 2013\Bin
C:\Program Files\Autodesk\Inventor 2013\Bin\Bin32
The tlb files have the same size and date.
1 REPLY 1
ekinsb
in reply to: oransen
The type library is the same for 32 and 64-bit so those files are the same, so it doesn't matter which one.  I would pick the one in the Bin directory.
Brian Ekins
Mod the Machine blog
