Does anyone know if there is a way to adjust the zoom amount within Inventor 2014 when using the mouse scroll wheel? I found a registry edit which seemed to have worked in prvious versions by modifying the Wheel Zoom Speed key but every time I start inventor it resets that value to default. Any suggestions would be appriciated.
http://www.cadforum.cz/cadforum_en/setting-the-mouse-wheel-zoom-factor-in-inventor-tip7835
I tried the setting that was described in the link you provided and it is working as expected. I changed the value to 0.5 and it has remained that value after several quits and re-starts of Inventor. Did you originally change the value while Inventor was running? It's possible that Inventor overwrote the value as it was shutting down.
