I need help again... the attached code lets me iterate through my IAM. It shows all of the IPT's in the IAM including the IPT's in a Sub.IAM. what am I not including in the code to get it to show me the User Parameters of all the components. This will only show the User Parameters of the Top Level IAM.
Thanks in advance
Bill
Public Sub ManipulateScrollParameters()
' ' Checks to see that an assembly file is open and ready for edit.
' If ThisApplication.Documents.Count = 0 Then
' MsgBox "You Must Have A Scroll Development Assembly Model Active "
' Exit Sub
' End If
' ' Checks to make sure that a part document is not active.
' If ThisApplication.ActiveDocumentType <> kAssemblyDocumentObject Then
' MsgBox " You Must Close All Part Files And Have" & vbCrLf & _
' "Only A Fan Scoll Development Open For Edit "
' Exit Sub
' End If
Dim oAssemDoc As AssemblyDocument
Set oAssemDoc = ThisApplication.ActiveDocument
Dim oAssemCompDef As AssemblyComponentDefinition
Set oAssemCompDef = oAssemDoc.ComponentDefinition
Dim oCompOccs As ComponentOccurrences
Set oCompOccs = oAssemCompDef.Occurrences
Dim oCompOcc As ComponentOccurrence
For Each oCompOcc In oCompOccs
Debug.Print oCompOcc.Name
Dim oIvCompOccEnum As ComponentOccurrencesEnumerator
Set oIvCompOccEnum = oCompOcc.SubOccurrences
Dim i As Integer
For i = 1 To oIvCompOccEnum.Count
Dim aa As Object
Set aa = oIvCompOccEnum.Item(i)
Debug.Print aa.Name
Next
Dim oIvParams As Parameters
Set oIvParams = oAssemCompDef.Parameters
Dim oIvUserParams As UserParameters
Set oIvUserParams = oIvParams.UserParameters
Dim oIvUserParam As UserParameter
Set oIvUserParam = oIvUserParams.Item(i)
Dim iNumParams As Long
Debug.Print "User Parameters"
For iNumParams = 1 To oIvUserParams.Count
Debug.Print " Name: " & oIvUserParams.Item(iNumParams).Name
Next
Next
End Sub
