It seems like I run into at least one "not implemented" method or property on every project, and it seems to be worse developing on a 64 machine (not that there should be any difference).
Latest one, trying to get Edges associated with a FilletConstantRadiusEdgeSet. In VBA, this fails the with the general 80004005 error code, typically meaning this method or property is not implemented.
Is this a 64bit problem? Sorry, don't have a 32 bit machine handy to try it here. If not, can we please get a halt to objects that are not fully implemented, especially when there is information in the help (another topic entirely) as to how it is designed to work.
There have been a few posts on things that seem to be issues in 2011, with no reply from any of the Autodesk regulars. Most noticibly is the behaviour (or the lack thereof) of running IV commands via the CommandManager.ControlDefinitions().Execute method. I've posted on some that don't work in VBA, and there are reports of it being disfunctional in C#.NET projects.
A general reply as to whether these are on any radar screen would be appreciated. Feel fee to add any experiences you've had along the same lines.
Solved by YuhanZhang. Go to Solution.
Thanks to reflect this issue. I see the same issue both on 32 bit and 64 bit machines, and addressed this issue with tracking number 1356918.
I´ll pick up your invitation:
No replies & seemingly no solution ATM.
I got a reminder from my colleague about this question, and recalled that this is as designed(sorry for my mistake), and the correct way to get the FilletConstantRadiusEdgeSet is that you have to rollback the fillet feature as the edge set the fillet feature based on would disappear after creating the fillet. To rollback the fillet feature you could call the API FilletFeature.SetEndOfPart(True), then you can retrieve the FilletConstantRadiusEdgeSet you need.
Hope this clarifys.
Thanks Rocky. The help does have this little gem of information, finding it is not very easy. Any chance you can check into the other issues brought up here that haven't been addressed.
