Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
what is the Inventor VBA code to constrain two parts using mate constraint?
1 REPLY 1
KpRj8560
3401 Views, 1 Reply
Hi all,
Can anyone help me?
Im looking for VBA codes to crate mate constraint between two parts?
I have crated two parts and called up those two parts in assembly document as occurances
but i'm unable to constrain it.
Please help
Regards
KP
1 REPLY 1
jdkriek
in reply to: KpRj8560
If you click on the help within Inventor you will see an option that says "Additional Resources", when you highlight that option on the menu a flyout will give you the option for "Programming Help".  Then select "Sample Code" from the side menu and look for "Assembly Constraints and iMates". This will give you several examples on how to do what you want.
If you need more help, let me me know.
Public Sub iMateResultCreationSample()
    'Get the component definition of the currently open assembly.
    'This will fail if an assembly document is not open.
    Dim oAsmCompDef As AssemblyComponentDefinition
    Set oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
    'Create a new matrix object.  It will be initialized to an identity matrix.
    Dim oMatrix As Matrix
    Set oMatrix = ThisApplication.TransientGeometry.CreateMatrix
    'Place the first occurrence.
    Dim oOcc1 As ComponentOccurrence
    Set oOcc1 = oAsmCompDef.Occurrences.Add("C:\Temp\iMatePart.ipt", oMatrix)
    'Place the second occurrence, but adjust the matrix slightly so they're
    'not right on top of each other.
    oMatrix.Cell(1, 4) = 10
    Dim oOcc2 As ComponentOccurrence
    Set oOcc2 = oAsmCompDef.Occurrences.Add("C:\Temp\iMatePart.ipt", oMatrix)
    'Look through the iMateDefinitions defined for the first occurrence
    'and find the one named "iMate:1".  This loop demonstrates using the
    'Count and Item properties of the iMateDefinitions object.
    Dim i As Long
    Dim oiMateDef1 As iMateDefinition
    For i = 1 To oOcc1.iMateDefinitions.Count
        If oOcc1.iMateDefinitions.Item(i).Name = "iMate:1" Then
            Set oiMateDef1 = oOcc1.iMateDefinitions.Item(i)
            Exit For
        End If
    Next
    If oiMateDef1 Is Nothing Then
        MsgBox "An iMate definition named ""iMate:1"" does not exist in " & oOcc1.Name
        Exit Sub
    End If
    'Look through the iMateDefinitions defined for the second occurrence
    'For Each method of iterating through a collection.
    Dim oiMateDef2 As iMateDefinition
    Dim bFoundDefinition As Boolean
    For Each oiMateDef2 In oOcc2.iMateDefinitions
        If oiMateDef2.Name = "iMate:1" Then
            bFoundDefinition = True
            Exit For
        End If
    Next
    If Not bFoundDefinition Then
        MsgBox "An iMate definition named ""iMate:1"" does not exist in " & oOcc2.Name
        Exit Sub
    End If
    'Create an iMate result using the two definitions.
    Dim oiMateResult As iMateResult
    Set oiMateResult = oAsmCompDef.iMateResults.AddByTwoiMates(oiMateDef1, oiMateDef2)
End Sub
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
