Argh...so you only get ONE shot to edit a post??
I've had to go to major lengths to get this far. I cannot open a forum listing page here without my IE locking up (and i don't have the ability to switch browsers). All other pages are fine, but the forum listings lock me up. And that's the only place to create a new post....
My last post got eaten so lets try take 3.
Essentially, i've got VS2012 and Inventor 2013.
I'm trying to create a new/first addin and we're trying to create icons on the ribbon for them. I've decided to get that process down first. I've been trying the write up here: http://modthemachine.typepad.com/my_weblog/2012/02/bitmaps-without-vb6-icontoipicture.html in the article it has a download for a functioning version. I've opened this and run the compile which states it compiled successfully. Problem is, i can't get it to open in inventor. I've got it publishing to the ...\inventor 2013\bin folder. Again, it says it built successfully, but whether i use debug or manually open inventor, i can't get it to open.
Is there something i'm missing? This is getting really frustrating at this point.
Mike
Hi Mike,
I would use a tool like Process Monitor and filter on the name of the Add-In dll. When in Inventor starts you can see if the dll is accessed.
http://technet.microsoft.com/en-us/sysinternals/cb56073f-62a3-4ed8-9dd6-40c84cb9e2f5.aspx
Double check the .addin file. Is the name of the assembly correct? If it is using a path is that correct? Also is the .addin file being found? (you could also use processmonitor to check).
There is a Add-Ins command on the Inventor Tools tab.The AddIn should be in the list in the Add-In manager.
You should also be able to add a break point and step through the code when Inventor is accessing the dll.
Wayne
