Hi all,
I'm just setting myself up on a new PC, and updating a few things along the way. I've gone from VS2005 to VS2010 express, and migrated my projects along the way. The migrated projects worked OK, but I've just started a new project and I can't figure out how to add a start up application for my project.
On the Debug tab in Project Properties, there's no option for startup application like there was in VS2005
Any ideas?
Thanks in Advanced
OK,
So I finally figured this problem out.
Details are here: http://through-the-interface.typepad.com/through_the_interface/2006/07/debugging_using.html
Now, I can't get the debugging to work, it doesn't hit breakpoints or display errors.
Cheers
Where did you find .vbpj.user file???????????????????????????????
Blowig my head
I feel like banging my head against wall
