Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Visible fence in the parent view of a detail view
2 REPLIES 2
ApostolosJK
619 Views, 2 Replies
Greetings everyone.
I create a detail view of a portion of an other view in my drawing but the problem is that I cannot show the fence that circulates the portion of the original view. I searched quite a lot in the API but I couldn't find a way of displaying the fence. Is there a way of doing this?
A workaround could be to create a circular arc in the exact place with the same radius as the fence but I'd rather show the fence itself.
Thank you in advance.
2 REPLIES 2
RodrigoEiras
in reply to: ApostolosJK
Hi ApostolosJK,
I think this is what you are looking for:
DetailDrawingView.DisplayDefinitionInBase Property
Parent Object: DetailDrawingView
Description
Property that gets and sets whether to display detail circles, section lines and the associated text in the base view. The property returns False and cannot be set where not applicable.
Syntax
DetailDrawingView.DisplayDefinitionInBase() As Boolean
Best regards
ApostolosJK
in reply to: RodrigoEiras
Well, thank you!
Mysteriously I had already been using that property but I was re-setting it to false further down to my code.....
