vba subfolder search
2 REPLIES 2
jdchakes
912 Views, 2 Replies
Hi
I am trying to search through a folder and all subsequent subfolders for a file matching a certain name.
I am having trouble getting this to work.
Here is the section of my code doing the searching. I keep getting a type mismatch on the 12th line
'Recursvly check all folders and subfolders for file matching BKT UID
'NOTE!! tools/Reference/'microsoft scripting runtime' must be ticked!!
Private Sub Recurse(oAsmPath As String, bktUID As String)
Dim FSO As New FileSystemObject
Dim myFolder As Folder
Dim mySubFolder As Folder
Dim myFile As File
Set myFolder = FSO.GetFolder(oAsmPath)
For Each mySubFolder In myFolder.SubFolders
For Each myFile In mySubFolder.Files
If InStr(myFile.Name, bktUID) <> 0 Then
Debug.Print myFile.Name & " in " & myFile.Path
Exit For
End If
Next
oAsmPath = mySubFolder.Path
Call Recurse(oAsmPath, bktUID)
Next
End Sub
I am not very experienced at programming at all so any help would be appreciated cheers!
2 REPLIES 2
rossano_praderi
in reply to: jdchakes
Hi Jd, this is my solution.
 Dim myFile 'As File
       'If InStr(Ucase(myFile.Name), Ucase(bktUID)) <> 0 Then 'not case sensitive as an example
          Exit For
       End If
    Next
 Next
End Sub
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
rossano_praderi
Hi Jd, have you found a solution?
Bregs
Rossano Praderi
