I'm writing a macro that exports .idw's to .dxf's. For each new revision we save a new copy with the revision number tagged onto the part number ( Example I00-001234 revision 1 becomes I00-001234R1).
The problem comes when i try to extract the revision number from the drawing. Because the drawing updates the revision from the model, the titleblock shows the model revision. However, when I pull the revision number, the code pulls the data from the sheet iproperties rather than the model iproperties.
Is there a way to pull the model revision, or a way to pull the data from the titleblock on the drawing?
Private SaveasDXF_Click()
Dim FSO As Scripting.FileSystemObject
Dim InvDocuments, Path As Documents
Dim invDocument As Document
Dim InvDoc, oDoc As Document
Dim FilePath As String
Dim newDXF As String
Dim PopUp As String
Dim Ans As String
Dim InvRevision As Property
Dim Revision As String
Set InvDoc = ThisApplication.ActiveDocument
Set Path = ThisApplication.Documents
Set InvRevision = InvDoc.PropertySets.Item("Inventor Summary Information").Item("Revision Number")
'^^^ This line reads the sheet revision (which is 0) but the model revision is 1
Set FSO = New Scripting.FileSystemObject
FilePath = "C:\TEMP" + newDXF
MsgBox "Revision Number: " & InvRevision.Value
If FSO.FileExists(FilePath) = False Then
If InvRevision.Value = Null Or 0 Then
Revision = ""
Else
Revision = "R" + CStr(InvRevision.Value)
newDXF = newDXF + Revision
End If
' Here I call the function to save copy as DXF
Else
PopUp = "Do you wish to overwrite the file" & vbNewLine & _
newDXF & "?"
Ans = MsgBox(PopUp, vbOKCancel, "Overwrite File?")
If Ans = vbOK Then
'Delete old file
With New FileSystemObject
.DeleteFile "C:\TEMP" & newDXF
End With
Revision = ""
Else
End If
' Here I call the code to save a copy as DXF
Else
End If
End If
End Sub
Solved by GVDB. Go to Solution.
I presume that you are in a idw when you call SaveasDXF
If so you must change:
into this:
Dim InvModelDoc as Inventor.Document
Set InvModelDoc = InvDoc..ReferencedDocuments(1)
Set InvRevision = InvModelDoc.PropertySets.Item("Inventor Summary Information").Item("Revision Number")
This gives you the revision of the model which belongs by the iDW
Thanks a lot. It works perfectly now.
The .idw wasn't the open document, but I solved this by changing:
to
Set InvDoc = Path.Item(j) (and of course moving this below the point where j is defined as the correct integer.)
