VBA Print Drawing from File
1 REPLY 1
CAD-e-Shack
450 Views, 1 Reply
Ive written a program in Inventor that finds all the drawings associated with a part/assembly.
it is supposed to find and open the selected drawings invisibly but for some reason the print manager wont work unless the drawing is opened and the drawing is active. In order to make the program work I have to open each drawing then close them. every time the user must input for save changes, and checking out (which is not necessary and takes forever).
Is there a way I can print without opening the drawing and making it active?
in the attached file, Ln 49-63
'Activate the selected document
            Set doc = ThisApplication.Documents.Open(Archive, False)
           ' The only way to make it work is to change this value to True. this sends up all sorts of pop up windows.
            Set osheets = doc.Sheets
                For X = 1 To osheets.Count
                size = osheets.item(X).size
                If first = False Then
                    Compare = size
                    first = True
                End If
' on second iteration print the document
                If Y = 2 Then
                    Call printMacro
                    Printed = True
                    'ThisApplication.ActiveDocument.Close True
                ' then I am forced to close it later which isn't a problem, it just takes time.
                    Exit For
                End If
1 REPLY 1
this is a design limitation, so the document needs to be open to print. This limitation arises from the fact that an invisible document does not have any 'views'. Unfortunately, there are no plans to fix this issue. Sorry for any inconvenience this may cause to you.
