I am receiving the following message when trying a run a VBA macro in Inventor 2014.
Run-time error '3706':
Provider cannot be found. It may not be properly installed.
It occurs at this line of code:
'Open connection With oCN .Provider = "Microsoft.ACE.OLEDB.12.0" .ConnectionString = sConnection .Open End With
I have a reference to the Microsoft ActiveX Data Objects 2.8 Library. I believe that the problem is related to the reference because this macro worked fine in 2011.
I am running Windows 7 64 bit and MS Office 32 bit. I have installed the Microsoft Access Database Engine 2010 Redistributable exe. I have tried changing the reference to 2.7 and 6.0 but I still get the error.
Any ideas on how to fix this?
Solved by ekinsb. Go to Solution.
I think you'll find this useful: http://forums.autodesk.com/t5/NET/32bit-AND-64bit-environment-database-connectivity/td-p/2925668
Cheers,
You might also find this post useful.
Thanks for the info and explanations Adam and Brian. Very helpful.
You may be able to install the exe via command line using -> AccessDatabaseEngine_x64.exe /passive
