VBA iPart - Value from iPart table
I am wondering if there is way how to get custom value from existing custom member inserted in assembly.
Why I need this: I am writing a code which will change row of a ipart member (.ChangeRow(sLine, iPartCustom) but I need to change some of the custom values as well. And before it I want to list the current values.
Hello again,
anybody who knows if possible?
thanks
Vladimir.Ananyev
Could you please consider the following code sample.
It gets the first component in the active assembly document  and assuming that it’s an iPartMember it prints all the iPartFactory table content.  You should use iPartTableCell.Value property to get or set the value of the cell (if this cell does not contain formula, to check this fact you may use the HasFormula property).  This sample changes the custom values in the 4th table row and save the new iPart member on the disk.
Finally ComponentOccurrence.Replace method is used to replace the current iPart member with the new one.
Sub Replace_iPartMember_in_Asm()
    'active assembly
    Dim oAssyDoc As Inventor.Document
    Set oAssyDoc = ThisApplication.ActiveDocument
    Call oAssyDoc.Update
    'assembly definition
    Dim oAssyDef As AssemblyComponentDefinition
    Set oAssyDef = oAssyDoc.ComponentDefinition
    'reference to the occurrence that represent iPart member
    '(here it is the first component in the browser)
    Dim oOcc As ComponentOccurrence
    Set oOcc = oAssyDef.Occurrences.Item(1)
    'part definition
    Dim oDef As PartComponentDefinition
    Set oDef = oOcc.Definition
    Dim oRow As iPartTableRow
    Dim oColumn As iPartTableColumn
    Dim i As Integer, j As Integer
    'reference to the iPart member
    Dim oMember As iPartMember
    Set oMember = oDef.iPartMember
    'reference to the iPart factory
    Dim oFactory As iPartFactory
    Set oFactory = oMember.ParentFactory
    'table columns list
    Dim oColumns As iPartTableColumns
    Set oColumns = oFactory.TableColumns
    'table rows list
    Dim oRows As iPartTableRows
    Set oRows = oFactory.TableRows
    'print the  current table content
    'headers
    Debug.Print "i",
    For j = 1 To oColumns.Count
        Set oColumn = oColumns.Item(j)
        Debug.Print oColumn.DisplayHeading,
    Next j
    Debug.Print
    'table cells' values
    For i = 1 To oRows.Count
        Set oRow = oRows.Item(i)
        Debug.Print i,
            Debug.Print oRow.Item(j).value,
        Next j
        Debug.Print
    Next
    'current custom values in the given row (4th here)
    Set oRow = oRows.Item(4)
    Debug.Print oRow.Item(3).value, oRow.Item(4).value
    'set new custom values
    oRow.Item(3).value = "2 in"
    oRow.Item(4).value = "25 deg"
    'new filename
    Dim newFilename As String
    newFilename = oFactory.MemberCacheDir & "\" & "A" & oMember.Name
    Debug.Print "newFilename = " & newFilename
    'create new member
    Dim oNewMember As iPartMember
    Set oNewMember = oFactory.CreateCustomMember(newFilename, 4)
    oFactory.Parent.Update
    oFactory.Parent.Save
    'replace file reference
    Call oOcc.Replace(newFilename, False)
    'headers
    Debug.Print "i",
    Next j
    Debug.Print
        Debug.Print i,
        Next j
        Debug.Print
    Next
    Beep
End Sub
before                                                           after
Debug print:
i             Member        Part Number   d0            d1
 1            Part1-01      Part1-01      3             0 deg
 2            Part1-03      Part1-03      2 in          5 deg
 3            Part1-04      Part1-04      3 in          10 deg
 4            Part1-02      Part1-02      4 in          10 deg
4 in          10 deg
2 in          25 deg
newFilename = C:\PR\iPart_Demo\iPart_Custom\APart1-042.ipt
 4            Part1-02      Part1-02      2 in          25 deg
cheers,
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
Hello Vladimir,
thanks!
Is there any way to get the current row of the iPart inserted in the assembly?
Jiri
Vladimir.Ananyev
No problem.  iPartTableRow object gives you access to any row properties:
Dim oDoc As PartDocument
Set oDoc = ThisApplication.ActiveDocument
Set oDef = oDoc.ComponentDefinition
'reference to the table row
Set oRow = oMember.Row
'print some row properties
Debug.Print "MemberName: " & oRow.MemberName
Debug.Print "PartName: " & oRow.PartName
Debug.Print "Index: " & oRow.index
 cheers,
Vladimir Ananyev
thank you for your help!
