I wroted an vba program to cycle through edges, but my code also produces edges that are not "true" work edges and are result of spline connecting straight edge. I marked those edges that I do not want to be exported on picture "part.png" file.
For example edge number 200 (mark on capture...jpg file). Is there a way to distinguish such edge (a property in VBA) and prevent it to be exported to csv file?
Here is VBA code:
Sub ExportEdges()
Dim oApp As Application
Set oApp = ThisApplication
Dim oPart As PartDocument
Set oPart = oApp.ActiveDocument
Dim oCompDef As ComponentDefinition
Set oCompDef = oPart.ComponentDefinition
Dim oFaces As Faces
Dim oFace As Face
Dim oEdge As Edge
Dim x1 As Double
Dim y1 As Double
Dim z1 As Double
Dim x2 As Double
Dim y2 As Double
Dim z2 As Double
Dim cx As Double
Dim cy As Double
Dim cz As Double
Dim p As Point
Dim l As Long
Dim pline As Polyline3d
Dim points() As Double
Dim edgeNo As Integer
Dim vertexCoordinates() As Double
Dim vertexIndices() As Long
Open "c:\Users\klemen\Dropbox\TerasaBoris\grbl\data.csv" For Output As #1
Dim objUOM As UnitsOfMeasure
Dim oCOM As Point
Dim oDoc As Inventor.Document
Dim oWS As WorkSurface
Set objUOM = oPart.UnitsOfMeasure
Set oCOM = oCompDef.MassProperties.CenterOfMass
maxX = oCompDef.RangeBox.MaxPoint.X
maxY = oCompDef.RangeBox.MaxPoint.Y
maxZ = oCompDef.RangeBox.MaxPoint.Z
minX = oCompDef.RangeBox.MinPoint.X
minY = oCompDef.RangeBox.MinPoint.Y
minZ = oCompDef.RangeBox.MinPoint.Z
centerX = (maxX + minX) / 2
centerY = (maxY + minY) / 2
centerZ = (maxZ + minZ) / 2
cogx = objUOM.GetStringFromValue(oCOM.X, UnitsTypeEnum.kDefaultDisplayLengthUnits)
cogy = objUOM.GetStringFromValue(oCOM.Y, UnitsTypeEnum.kDefaultDisplayLengthUnits)
cogz = objUOM.GetStringFromValue(oCOM.Z, UnitsTypeEnum.kDefaultDisplayLengthUnits)
'This can be changed to .SideFaces, .EndFaces, or .StartFaces
'But .Faces will let you choose between all faces
Set oFaces = oCompDef.SurfaceBodies.Item(1).Faces
edgeNo = 0
surfaceNo = 0
pointNo = 0
'oAssyDoc = ThisApplication.ActiveDocument
Set oDoc = ThisApplication.ActiveDocument
'For Each oDoc In oAssyDoc.AllReferencedDocuments
'set surface bodies visibility
For Each oFace In oDoc.ComponentDefinition.SurfaceBodies.Item(1).Faces
surfaceNo = surfaceNo + 1
For Each oEdge In oFace.Edges
'Debug.Print oEdge.GeometryForm & " " & oEdge.GeometryType
If oEdge.GeometryType = kBSplineCurve Then
Debug.Print "kLineSegmentCurve"
ElseIf oEdge.GeometryType = kCircleCurve Then
'Debug.Print "kCircleCurve"
ElseIf oEdge.GeometryType = kPolylineCurve Then
Else
'Debug.Print oEdge.GeometryType
Debug.Print oEdge.Type
If edgeNo = 199 Or edgeNo = 200 Then
Debug.Print oEdge.TangentiallyConnectedEdges.Count
Debug.Print oEdge.Parent.AppearanceSourceType
For k = 1 To oEdge.EdgeUses.Count
Debug.Print oEdge.EdgeUses.Item(k).GeometryForm
Next k
Debug.Print oEdge.TransientKey
': AppearanceSourceType: kPartAppearance: AppearanceSourceTypeEnum: Module1.Sketch2Face2
edgeNo = edgeNo + 1
Set pline = ThisApplication.TransientGeometry.CreatePolyline3dFromCurve(oEdge.Geometry, 0.005)
pointsStr = ""
For l = 1 To pline.PointCount
pointNo = pointNo + 1
Set p = pline.PointAtIndex(l)
pointsStr = pointsStr & (p.X - centerX) & ";" & (p.Y - centerY) & ";" & (p.Z - centerZ) & ";"
Next l
pointsStr = Left(pointsStr, Len(pointsStr) - 1)
Print #1, "POLY_" & Trim(Str(surfaceNo)) & "_" & Trim(Str(edgeNo)) & "_" & pointNo & ";" & pointsStr
Next
Next
'Next
Close #1
End Sub
This is old post - I had problems with attachments - site mentioned I can have only 3 attachments - but I added only three - however latest post was succesfull - so please site admin delete this post.
Sorry for inconvinience.
