Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
VBA: Distinguis​h hole features from other circles in drawing, add centermark​s.
4 REPLIES 4
2437 Views, 4 Replies
I'm attempting to use VBA to put center marks on each hole in my drawing.
So far I have the following code:
    Dim oIntent As GeometryIntent
    Dim oCenterOfPart As Centermark
    'Add center marks to base view
    For Each oCurve In oBaseView.DrawingCurves ' <- need to identify Hole Features
        If Not oCurve.CenterPoint Is Nothing Then
            If oCurve.CurveType = kCircleCurve Then 'CurveTypeEnum
                Set oIntent = oSheet.CreateGeometryIntent(oCurve)
                Set oCenterOfPart = oSheet.Centermarks.Add(oIntent, True, True)
    Next oCurve
    'Add center marks to top view
    For Each oCurve In oTopView.DrawingCurves ' <- need to identify Hole Features
    Next oCurve
    'Add center marks to right view
    For Each oCurve In oRightView.DrawingCurves ' <- need to identify Hole Features
    Next oCurve
oBaseView is the DrawingView object representing the base view the code just placed. I also used VBA to place the projected views oTopView and oRightView. I want to add center marks to each hole when viewed from the end (as circles) and add centerlines when viewed from the top or side (as hidden lines).
I will be iterating through several models representing various handhold styles. The feet can be in many orientations, 99% of them are paralel to one of the origin planes (XY,YZ, or XZ).
This is what my code generates:
 (The centermarks that are selected are the ones I don't want the code to generate)
 This is what I WANT the code to generate:
 1) How do I distinguish whether a circle curve originated because of a hole or because of another cilindrical feature?
2) How to I identify the correspoding hidden lines in the other views so I can add a center line?
(Reposted from: http://forums.autodesk.com/t5/Autodesk-Inventor/VBA-Distinguish-hole-features-from-other-circles-in-...)
4 REPLIES 4
Hi CragMonkey
With my automatic drawing program I call up the automatedCenterlines, the same as if you were to RMB on each view and select automated center lines.
Code:
oSheet is the active drawing sheet,
oSheet.DrawingViews.Item(1).SetAutomatedCenterlineSettings()
oSheet.DrawingViews.Item(2).SetAutomatedCenterlineSettings()
oSheet.DrawingViews.Item(3).SetAutomatedCenterlineSettings()
In your drawing template yo need to set your default Automated centerlines,
Tools > Document Settings > Automated Centerlines > Select required centerlines.
This should set all your default centerlines for the three views
Ash
The holes were created not by using the hole function, but instead by excluding that area during the extrusion. Inventor is seeing them both as "Cylindrical Features" - the result is the same as the other code.
However, when I create a hole table it knows the difference and correctly identifies the holes. I'm just not sure how to leverage that for this purpose.
xiaodong_liang
I did no find a direct way, but at least you can get DrawingCurve.ModelGeometry which is an edge. Next iterate Edge.Faces. If the face is a cylinder, get Face.CreateByFeature. Thus you can know if the feature is a hole feature or other features. Hope this helps.
b.gyure
Hi CragMonkey 2000 !
I realize this is an old post but it might come in handy for others too. I was looking for the same thing so I wrote the code for it. Granted I'm not done, since I would need it for drawing which has an an assembly in it, so far I only did it for a drawing that has a part file in it. I'll try and finish it for both, for now with a part file, it works.
You might have to tweak it a bit for it to do for all of the sheets and all of the partfiles but I think that's going to be a piece of cake. Here is my code:
If you can use this please give a thumbs up, or accept it as a solution, thank you!
Sub CenterMark()
Dim oDrawDoc As DrawingDocument
Set oDrawDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
Set oSheet = oDrawDoc.ActiveSheet
Dim oBaseView As DrawingView
Set oBaseView = oSheet.DrawingViews.Item(1)
Dim oDoc As PartDocument
Set oDoc = oBaseView.ReferencedDocumentDescriptor.ReferencedDocument
Dim oDef As PartComponentDefinition
Set oDef = oDoc.ComponentDefinition
Dim oHoleFeatures As HoleFeatures
Set oHoleFeatures = oDef.Features.HoleFeatures
Dim oColl As ObjectCollection
Set oColl = ThisApplication.TransientObjects.CreateObjectCollection
Dim oHole As HoleFeature
For Each oHole In oHoleFeatures
Dim oCurves As DrawingCurvesEnumerator
Set oCurves = oBaseView.DrawingCurves(oHole)
For Each oCurve In oCurves 'oBaseView.DrawingCurves ' <- need to identify Hole Features
'If oCurve.Type = kHoleFeatureObject Then
Next oCurve
'oColl.Add (oCurves.Item(1)
'''IMMEDIATE WINDOW
Debug.Print oHole.Name, oCurves.Count
Next
' Dim oIntent As GeometryIntent
' Dim oCenterOfPart As CenterMark
'Dim oCurve As DrawingCurve
End Sub
And I wrote a delete centermark too, so we can play around:
Sub DeleteCenterMarks()
'Dim oDoc As DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
Set oSheet = oDoc.ActiveSheet
Dim oCenterMark As CenterMark
For Each oCenterMark In oSheet.Centermarks
oCenterMark.Delete
Next
End Sub
