Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
VBA: Distinguis​h hole features from other circles in drawing, add centermark​s.
4 REPLIES 4
2432 Views, 4 Replies
I'm attempting to use VBA to put center marks on each hole in my drawing.
So far I have the following code:
    Dim oIntent As GeometryIntent
    Dim oCenterOfPart As Centermark
    'Add center marks to base view
    For Each oCurve In oBaseView.DrawingCurves ' <- need to identify Hole Features
        If Not oCurve.CenterPoint Is Nothing Then
            If oCurve.CurveType = kCircleCurve Then 'CurveTypeEnum
                Set oIntent = oSheet.CreateGeometryIntent(oCurve)
                Set oCenterOfPart = oSheet.Centermarks.Add(oIntent, True, True)
            End If
        End If
    Next oCurve
    'Add center marks to top view
    For Each oCurve In oTopView.DrawingCurves ' <- need to identify Hole Features
            End If
        End If
    Next oCurve
    'Add center marks to right view
    For Each oCurve In oRightView.DrawingCurves ' <- need to identify Hole Features
            End If
        End If
    Next oCurve
oBaseView is the DrawingView object representing the base view the code just placed. I also used VBA to place the projected views oTopView and oRightView. I want to add center marks to each hole when viewed from the end (as circles) and add centerlines when viewed from the top or side (as hidden lines).
I will be iterating through several models representing various handhold styles. The feet can be in many orientations, 99% of them are paralel to one of the origin planes (XY,YZ, or XZ).
This is what my code generates:
 (The centermarks that are selected are the ones I don't want the code to generate)
 This is what I WANT the code to generate:
 1) How do I distinguish whether a circle curve originated because of a hole or because of another cilindrical feature?
2) How to I identify the correspoding hidden lines in the other views so I can add a center line?
(Reposted from: http://forums.autodesk.com/t5/Autodesk-Inventor/VBA-Distinguish-hole-features-from-other-circles-in-...)
4 REPLIES 4
00ash00
Hi CragMonkey
With my automatic drawing program I call up the automatedCenterlines, the same as if you were to RMB on each view and select automated center lines.
Code:
oSheet is the active drawing sheet,
oSheet.DrawingViews.Item(1).SetAutomatedCenterlineSettings()
oSheet.DrawingViews.Item(2).SetAutomatedCenterlineSettings()
oSheet.DrawingViews.Item(3).SetAutomatedCenterlineSettings()
In your drawing template yo need to set your default Automated centerlines,
Tools > Document Settings > Automated Centerlines > Select required centerlines.
This should set all your default centerlines for the three views
Ash
Ash
Dell - T1650
Intel(R)Xeon(R) CPU E3-1290 V2 @ 3.70GHz
16GB
64-Bit
Windows 7 Pro
Inventor 2013 Build: 138
in reply to: 00ash00
The holes were created not by using the hole function, but instead by excluding that area during the extrusion. Inventor is seeing them both as "Cylindrical Features" - the result is the same as the other code.
However, when I create a hole table it knows the difference and correctly identifies the holes. I'm just not sure how to leverage that for this purpose.
xiaodong_liang
I did no find a direct way, but at least you can get DrawingCurve.ModelGeometry which is an edge. Next iterate Edge.Faces. If the face is a cylinder, get Face.CreateByFeature. Thus you can know if the feature is a hole feature or other features. Hope this helps.
b.gyure
Hi CragMonkey 2000 !
I realize this is an old post but it might come in handy for others too. I was looking for the same thing so I wrote the code for it. Granted I'm not done, since I would need it for drawing which has an an assembly in it, so far I only did it for a drawing that has a part file in it. I'll try and finish it for both, for now with a part file, it works.
You might have to tweak it a bit for it to do for all of the sheets and all of the partfiles but I think that's going to be a piece of cake. Here is my code:
If you can use this please give a thumbs up, or accept it as a solution, thank you!
Sub CenterMark()
Dim oDrawDoc As DrawingDocument
Set oDrawDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
Set oSheet = oDrawDoc.ActiveSheet
Dim oBaseView As DrawingView
Set oBaseView = oSheet.DrawingViews.Item(1)
Dim oDoc As PartDocument
Set oDoc = oBaseView.ReferencedDocumentDescriptor.ReferencedDocument
Dim oDef As PartComponentDefinition
Set oDef = oDoc.ComponentDefinition
Dim oHoleFeatures As HoleFeatures
Set oHoleFeatures = oDef.Features.HoleFeatures
Dim oColl As ObjectCollection
Set oColl = ThisApplication.TransientObjects.CreateObjectCollection
Dim oHole As HoleFeature
For Each oHole In oHoleFeatures
Dim oCurves As DrawingCurvesEnumerator
Set oCurves = oBaseView.DrawingCurves(oHole)
For Each oCurve In oCurves 'oBaseView.DrawingCurves ' <- need to identify Hole Features
'If oCurve.Type = kHoleFeatureObject Then
End If
End If
Next oCurve
'oColl.Add (oCurves.Item(1)
'''IMMEDIATE WINDOW
Debug.Print oHole.Name, oCurves.Count
Next
' Dim oIntent As GeometryIntent
' Dim oCenterOfPart As CenterMark
'Dim oCurve As DrawingCurve
End Sub
And I wrote a delete centermark too, so we can play around:
Sub DeleteCenterMarks()
'Dim oDoc As DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
Set oSheet = oDoc.ActiveSheet
Dim oCenterMark As CenterMark
For Each oCenterMark In oSheet.Centermarks
oCenterMark.Delete
Next
End Sub
