Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
VBA Difference executing Inside or Outside sketch
2 REPLIES 2
ArjanDijk
342 Views, 2 Replies
Public Sub MoveSketchObjects()
    ' Check to make sure a sketch is open.
    If Not Typeof ThisApplication.ActiveEditObject Is Sketch Then
        MsgBox "A sketch must be active."
        Exit Sub
    ' Set a reference to the active sketch.
    Dim oSketch As Sketch
    Set oSketch = ThisApplication.ActiveEditObject
    ' Create a vector along the x-axis.
    Dim oVec As Vector2d
    Set oVec = ThisApplication.TransientGeometry.CreateVector2d(5, 0)
    Dim oSketchObjects As ObjectCollection
    Set oSketchObjects = ThisApplication.TransientObjects.CreateObjectCollection
    ' Get all entities in the sketch
    Dim oSketchEntity As SketchEntity
    For Each oSketchEntity In oSketch.SketchEntities
        oSketchObjects.Add oSketchEntity
    Next
    ' Move all sketch objects along x-axis by 5 units.
    ' This will move all the text boxes and images in
    ' the sketch as well since these have sketch lines
    ' as boundary geometry or a sketch point as an
    ' origin point.
    Call oSketch.MoveSketchObjects(oSketchObjects, oVec)
End Sub
Hello. I'm trying to find out if I can execute move commands like the one in this example also witout having to open the sketch?
What code will I need in that case?
Inventor HSM and Fusion 360 CAM trainer and postprocessor builder in the Netherlands and Belgium.
2 REPLIES 2
YuhanZhang
in reply to: ArjanDijk
In part/Assembly document you can edit sketch entities without activating it, but after editing the sketch you'd better to call Document.Update to make sure the edit takes effect to update the graphic window. But for drawing sketch you have to activate it before you can edit the entities in it. Hope this helps.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
t_remal
I think you cannot move sketch objects without opening the sketch first.
However, you can open the sketch from VBA by calling oSketch.Edit and close it with oSketch.ExitEdit.
I changed your sub MoveSketchObjects to accept one parameter (the sketch to edit):
Public Sub MoveSketchObjects(oSketch As Sketch)
    Next
    ' Open the sketch for editing.
    Call oSketch.Edit
    ' origin point.
    ' Close the sketch.
    Call oSketch.ExitEdit
End Sub
As you can see, Edit is called before MovesketchObjects and ExitEdit after.
You still need to get the parameter (sketch) from somewhere. Which sketch would you like to change? Selected one? All of them?
Here's some code for selected sketches:
Public Sub MoveSelectedSketches()
    For Each oSelection In ThisDocument.SelectSet
        If TypeOf oSelection Is Sketch Then
            Set oSketch = oSelection
            Call MoveSketchObjects(oSketch)
    Next
End Sub
Hope that helps!
Lubomir
