VBA: Copy all files in the Active document to a new location
Message 1 of 8
I am trying to create a VBA macro to copy al of the files referenced in the active document to a new location.
Some similar Apprentice examples use the Inventor.FileSaveAs to collect all of the references before executing the save as but I cannot get it to work.
Here is my code limited to just the current document for testing purposes:
it fails at:   Call oFileSaveAs.AddFileToSave(oDoc, sTargetFile)
   ' Set references to active document, Target Directory, Filename.
   Dim oDoc As Inventor.Document
   Set oDoc = ThisApplication.ActiveDocument
   Dim sFullFileName As String
   sFullFileName = oDoc.FullFileName
   Dim sFilename As String
   sFilename = Right(sFullFileName, Len(sFullFileName) - InStrRev(sFullFileName, "\"))
   ' Set Target Directory & Filename
   Dim sTargetDir As String
   sTargetDir = "C:\Test\"
Dim sTargetFile As String
   sTargetFile = sTargetDir & sFilename
' Set a reference to the FileSaveAs object.
   Dim oFileSaveAs As Inventor.fileSaveAs
   Call oFileSaveAs.ExecuteSave
Any help would be appreciated.
Alasdair
References used:
http://forums.autodesk.com/t5/inventor-customization/copy-assembly-similar-to-pack-and-go/m-p/265181...
http://www.mcadforums.com/forums/viewtopic.php?f=15&t=12087&p=84255&hilit=filesaveas#p84255
SDK sample: C:\Users\Public\Documents\Autodesk\Inventor 2013\SDK\UserTools\CopyDesign\Source\form1.vb
Replies (7)
Message 2 of 8
I have resolved this issue, for anyone that needs to do something similar here is the final code.
Public Sub Copy()
   sTargetDir = "C:\Temp\"
   'Check to see if the file is already in the target directory If sFullFileName = sTargetFile Then GoTo FileExists ' Copy the Active Document Call oDoc.SaveAs(sTargetFile, True) ' Get all of the documents referenced by the active document. Dim allRefDocs As Inventor.Documents ' Dim oRefDoc As Inventor.Document For Each oRefDoc In oDoc.AllReferencedDocuments ' Get the full filename of the current document. Dim sRefFullFilename As String sRefFullFilename = oRefDoc.FullFileName Dim sRefFilename As String sRefFilename = Right(sRefFullFilename, Len(sRefFullFilename) - InStrRev(sRefFullFilename, "\")) Dim sRefTargetFile As String sRefTargetFile = sTargetDir & sRefFilename ' Copy the Reference Documents, check if they exist already If Dir(sRefTargetFile) = "" Then Call oRefDoc.SaveAs(sRefTargetFile, True) End If Next ' Close Current Document & Open New document Call oDoc.Close Dim oNewDoc As Inventor.Document Set oNewDoc = ThisApplication.Documents.Open(sTargetFile) 'ZoomAll ThisApplication.ActiveView.Fit True GoTo Finished FileExists: MsgBox "Your file is already in C:\Temp..." Finished: End Sub
Message 3 of 8
Can you write a code which can copy the flat pattern view (if present) from all drawings(.idw) in a folder into one common development drawing?
Message 4 of 8
Hi alasdair,
I have found your code to be useful but i would like to modify it a little and need some help.
I changed the string srefFileName to:
sRefFilename = "1130" & Right(sRefFullFilename, 17)
This saves the reference files in this format successfully.But inside the part file the iproperty as well as model browser name does not change according to the file name.
Is there a way i can incorportate the change in this code itself so that the iproperty name becomes same as the filename?
I would be grateful for your help.
Sid
using Inventor 2011
Message 5 of 8
Hi Sid,
I have not tried to update iProperties from the filename but this should be possible.
To get the filename without extension you can use:
   ' Get Filename
    Dim sFullPathFilename As String
    sFullPathFilename = FullFileName
    sFullFileName = Right(sFullPathFilename, Len(sFullPathFilename) - InStrRev(sFullPathFilename, "\"))
    sFilename = Left(sFullFileName, Len(sFullFileName) - 4)
Also see:
http://modthemachine.typepad.com/my_weblog/2010/05/working-with-filenames.html
Then set the property you want to sFilename with something like this:
 ' Get the design tracking property set.
 Dim invDesignInfo As PropertySet
 Set invDesignInfo = invDoc.PropertySets.Item("Design Tracking Properties")
'Set the Part number to filename
 Dim invProjectProperty As Property
 Set invProjectProperty = invDesignInfo("Part Number")
 invProjectProperty.Value = "sFilename"
More Info: http://download.autodesk.com/us/community/mfg/Part_2.pdf
I hope that helps.
Alasdair
Message 6 of 8
fakeru
The code works good, except when trying to copy frame generator assemblies. It cannot save the skeleton.ipt part. It says it must be saved together with frame.iam.
Any solutions to this?
Regards
Alexandru
Autodesk Inventor 2015 Certified Professional
Message 7 of 8
Hi Alexandru,
You could try a different approach if it doesn't work for Frame Generator asemblies.
  1. List all files in the Active Document
  2. Copy them using VBA instead of Save As
  3. Close the current Document
  4. Open the copied Document
Here is some code for listing all of the files in the active docuemnt
Dim oDoc As Document
Dim Refs As String
Refs = ThisApplication.ActiveDocument.FullDocumentName & vbCrLf
For i = 1 To oDoc.AllReferencedDocuments.count
Refs = Refs & oDoc.AllReferencedDocuments.Item(i).FullDocumentName & vbCrLf
Next
Message 8 of 8
amarcoc
Hi.
Loved this code!
I only want to copy files in workspace folder, and avoid library files.
Any way to keep folder hierarchy as in Workspace?
Thanks!
