Can anybody help????
I have a part (ipt) containing various holes drilled on various pitch circle diameters (see attached part)
The part in question has 3 separate circular patterns,
Does anybody know how I can tell what sketch goes with what pattern?
I have the following macro that I am using but it crashes on the line
Set oParentFeature = oCP.ParentFeatures.Item(1)
this is the macro:-
Public Function ArrayGeometry(Doc As PartDocument, sketch As PlanarSketch)
Dim oDef As PartComponentDefinition
Set oDef = Doc.ComponentDefinition
Dim oPar As Inventor.Parameter
Dim oFPE As FeaturePatternElement
Dim oParentFeature As ExtrudeFeature
Dim oSketch As PlanarSketch
Dim oCP As CircularPatternFeature
For Each oCP In oDef.Features.CircularPatternFeatures
Set oCP = oDef.Features.CircularPatternFeatures.Item(oCP.Name)
Set oParentFeature = oCP.ParentFeatures.Item(1) THIS IS THE PROBLEM LINE!!!
Set oSketch = oParentFeature.Profile.Parent
If oSketch.Name = sketch.Name Then MsgBox "entity is part of " + Ocp.Name
End Function
Any help would be appreciated!!!!!
Many thanks in advance
IsoCAM
