Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
VBA: Access PartDocume​nt object of iPart Factory, given iPart Member.
1 REPLY 1
CragMonkey
1196 Views, 1 Reply
How do I access the PartDocument object belonging to the iPart Factory that generated a given iPart Member?
Is there a way to access the file name of the factory that generated an iPart Member?
Dim oModelMember As PartDocument
Dim oModelFactory As PartDocument
Set oModelMember = ThisApplication.Documents.Open("C:\Temp\Handholds\142 - HH Style 13\142-32-1995 HANDHOLD, STYLE 13R.ipt", False)
Set oModelFactory = ThisApplication.Documents.Open("C:\Temp\Handholds\142 - HH Style 13.ipt", False)
I want to be able to open oModelFactory given oModelMember. I will be iterating through over a hundred different oModelMembers, so doing this manually would be tedious.
Any ideas?
1 REPLY 1
JohanLarsson
in reply to: CragMonkey
I have not used iParts much and dont know if this is what you want to do:
Public Sub PartTest()
    Dim oPartDoc As PartDocument
    Set oPartDoc = ThisApplication.ActiveDocument
    MsgBox (oPartDoc.ReferencedDocumentDescriptors(1).FullDocumentName)
End Sub
Inventor Professional 2012 SP1 (25 seats with subscription)
Windows 7 64 bit
Lenovo D20, 12 GB RAM, Intel Xeon X5687 3.6 GHz, SSD
Quadro 4000, driver 8.17.12.9573, dual monitors
SpacePilot, driver version 6.15.3 Firmware 3.12
