Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
VB to change Custom Table Title and Header Cell / Row Height
3 REPLIES 3
3080 Views, 3 Replies
When you make a custom table in VB.net, adding in the Row Height property in the custom table create line only changes the data cell row heights, not the title cells or the header cell.  How do yo do set the title/header cell row heights ?
Dim oRowHeights_FS(11) As Double
oRowHeights_FS(0) = 0.6
oRowHeights_FS(1) = 0.6
oRowHeights_FS(2) = 0.6
oRowHeights_FS(3) = 0.6
oRowHeights_FS(4) = 0.6
oRowHeights_FS(5) = 0.6
oRowHeights_FS(6) = 0.6
oRowHeights_FS(7) = 0.6
oRowHeights_FS(8) = 0.6
oRowHeights_FS(9) = 0.6
oRowHeights_FS(10) = 0.6
oRowHeights_FS(11) = 0.6
Dim position_FrameShear As Point2d = _invApp.TransientGeometry.CreatePoint2d((oInvSheet.Border.RangeBox.MinPoint.X + 16), (oInvSheet.Border.RangeBox.MaxPoint.Y))
Dim oCustomTable_FrameShear As CustomTable
oCustomTable_FrameShear = oInvSheet.CustomTables.Add(vValue_FrameType & " " & vValue_Hand & " Frame Shear List", position_FrameShear, 6, 12, oTitles_FrameShear, oContents_FrameShear, oColumnWidths_FrameShear, oRowHeights_FS)
3 REPLIES 3
xiaodong_liang
hi,
you will need to set the table style. e.g.
Public Sub CreateCustomTable()
    ' Set a reference to the drawing document.
    ' This assumes a drawing document is active.
    Dim oDrawDoc As DrawingDocument
    Set oDrawDoc = ThisApplication.ActiveDocument
    ' Set a reference to the active sheet.
    Dim oSheet As Sheet
    Set oSheet = oDrawDoc.ActiveSheet
    ' Set the column titles
    Dim oTitles(1 To 3) As String
    oTitles(1) = "Part Number"
    oTitles(2) = "Quantity"
    oTitles(3) = "Material"
    ' Set the contents of the custom table (contents are set row-wise)
    Dim oContents(1 To 9) As String
    oContents(1) = "1"
    oContents(2) = "1"
    oContents(3) = "Brass"
    oContents(4) = "2"
    oContents(5) = "2"
    oContents(6) = "Aluminium"
    oContents(7) = "3"
    oContents(8) = "1"
    oContents(9) = "Steel"
    ' Set the column widths (defaults to the column title width if not specified)
    Dim oColumnWidths(1 To 3) As Double
    oColumnWidths(1) = 2.5
    oColumnWidths(2) = 2.5
    oColumnWidths(3) = 4
      Dim oRowHeights_FS(2) As Double
oRowHeights_FS(0) = 1
oRowHeights_FS(1) = 1
oRowHeights_FS(2) = 1
     oDrawDoc.StylesManager.ActiveStandardStyle.ActiveObjectDefaults.TableStyle.HeadingGap = 1
    ' Create the custom table
    Dim oCustomTable As CustomTable
    Set oCustomTable = oSheet.CustomTables.Add("My Table", ThisApplication.TransientGeometry.CreatePoint2d(15, 15), _
                                        3, 3, oTitles, oContents, oColumnWidths, oRowHeights_FS)
End Sub
in reply to: xiaodong_liang
Finally got around to trying this and it does indeed work, thank you.
Wanted to add for future reference that my initial thought was setting the number would be the actual row height, when indeed, as the code states, it's a gap, so it's the space around the text in the column heading.  I set it to .150  and it worked great.
oDrawDoc.StylesManager.ActiveStandardStyle.ActiveObjectDefaults.TableStyle.HeadingGap = 0.150
Hi! Is there a way to use this method. But then also hide the title block and have it list the columns from the top - down. It's easy to do within the style editor but I'd like to be able to do it with iLogic.
