(Image attached). I am using Inventor 2013 and Visual Basic 2010 Express. I created a sketch within one of my views on my .idw. I would like to turn this sketch on or off based on the input from a variable that is read elsewhere. I have used the following code from the help file with no luck so far.
Public Sub SketchEdit() Dim oDrawDoc As DrawingDocument oDrawDoc = _invApp.ActiveDocument ' Determine if there are any sheet overlay sketches. Dim oSketches As DrawingSketches oSketches = oDrawDoc.ActiveSheet.Sketches If oSketches.Count = 0 Then Exit Sub End If ' Set a reference to the first sketch. Dim oSketch As DrawingSketch oSketch = oSketches.Item(4) oSketch.Edit() If vValue_Closer = "" Then oSketch.LineWeight = 0 Else oSketch.LineWeight = 0.007 End If ' Return from edit mode. oSketch.ExitEdit() End Sub
The code errors out on the line 'osketch = osketches.item(4)'. I have tried using a number like that, and I have also tried using the actual name of the sketch. Neither works.
oSketch = oSketches.Item("Closer_Reinf")
Any advice on what to edit here to get it to look at my Closer_Reinf sketch to hide it/unhide it ?
Solved by YuhanZhang. Go to Solution.
As it turns out, my error lied in how I referenced the sketch. Making a reference to just a sketch only looks for sketches on the sheet, not within a view. I had to declare my view, then the sketch within the view. I also found that changing the color to white from black hid it from printing in the PDF, which proved to be easier than fooling with lineweights.
Here is the new fixed code for future reference in case anyone can utilize it.
Public Sub SketchEdit() Dim oDrawDoc As DrawingDocument oDrawDoc = _invApp.ActiveDocument Dim oSheet1_View As DrawingView = oDrawDoc.Sheets(1).DrawingViews(1) Dim oSketch As DrawingSketch oSketch = oSheet1_View.Sketches.Item(2) Dim oColor_White As Color Dim oColor_Black As Color oColor_White = _invApp.TransientObjects.CreateColor(255, 255, 255) 'White oColor_Black = _invApp.TransientObjects.CreateColor(0, 0, 0) 'Black oSketch.Edit() If vValue_Closer = "" Then oSketch.Color = oColor_White Else oSketch.LineType = LineTypeEnum.kDashedLineType oSketch.Color = oColor_Black End If ' Return from edit mode. oSketch.ExitEdit() End Sub
I thought I had it all figured out, and I was wrong. Changing the line color to white works in some instances, but I have another instance where I need to figure out how to hide the entire sketch from a drawing view. See attached pic. I am trying to hide a sketch I have made within a drawing view. The sketch is the hole representation.
My code is as follows:
Public Sub SketchEdit_Flange_Holes() Dim oDrawDoc As DrawingDocument oDrawDoc = _invApp.ActiveDocument Dim oColor_White As Color Dim oColor_Black As Color oColor_White = _invApp.TransientObjects.CreateColor(255, 255, 255) 'White oColor_Black = _invApp.TransientObjects.CreateColor(0, 0, 0) 'Black Dim oSheet1_View As DrawingView = oDrawDoc.Sheets(1).DrawingViews(4) 'View 4 - Section Cut Side View Dim oSketch_Top_Holes As DrawingSketch Dim oSketch_Bott_Holes As DrawingSketch oSketch_Top_Holes = oSheet1_View.Sketches.Item(2) oSketch_Top_Holes.Edit() If vValue_Flange_Holes = "N" Then oSketch_Top_Holes.Visible = False ElseIf vValue_Flange_Holes = "Y" Then oSketch_Top_Holes.Visible = True End If ' Return from edit mode. oSketch_Top_Holes.ExitEdit() If vValue_SillType = "F6" Then oSketch_Bott_Holes = oSheet1_View.Sketches.Item(3) oSketch_Bott_Holes.Edit() If vValue_Flange_Holes = "N" Then oSketch_Bott_Holes.Visible = False ElseIf vValue_Flange_Holes = "Y" Then oSketch_Bott_Holes.Visible = True End If ' Return from edit mode. oSketch_Bott_Holes.ExitEdit() Else 'Do Nothing End If End Sub
I tried turning it white like I did on the previous example, but because of it's placement, it whites out the lines behind it and that leaves gaps in my drawing. Plus it won't white out the filled portion.
When I run the code, it will throw an error on the first oSketch_Top_Holes.Visible = False line. The weird thing is, it won't throw an error on the oSketch_Top_Holes.Visible = True line. My assumption from my research is that the oSketch.Visible = True/False code is meant for part documents, not drawing documents. If that is the case, can someone point me towards the code required to suppress sketches in drawing views?
I have also tried omitting going in to Sketch Edit mode using the oSketch.Edit command, but that didn't work either.
Still looking for VB help to hide a sketch within a drawing view. If anyone has guidance, please post it up.
Set DrawingSketch.Visible = False is not working, in UI you can see the drawing sketch has not visibility command in its context menu.
I think what you want to do is to hide the drawing objects so they won't be printed. For drawing sketch curves you can set their SketchOnly = True to hide them, but for the hatched/filled regions currently there is no APIs to hide them(for filled regions you can either delete them or set the same color as the background, while for the hatched regions currently there is no API to access them).
So if your drawing sketch has only curves or filled regions that you can change them as I suggested above to hide them from printing.
Hope this helps!
Thank you for the response! Using your 'SketchOnly' term, I was able to find some more info on the matter, and came up with some code that works for turning on and off my sketched rectangle in one view. I haven't attempted to hide the filled region I have yet, that is coming next. Just wanted to share the code and say thanks again.
Public Sub SketchEdit_Closer_Reinf() Dim oDrawDoc As DrawingDocument oDrawDoc = _invApp.ActiveDocument Dim oSketches As DrawingSketches oSketches = oDrawDoc.ActiveSheet.Sketches Dim oSheet1_View As DrawingView = oDrawDoc.Sheets(1).DrawingViews(1) Dim oSketch As DrawingSketch oSketch = oSheet1_View.Sketches.Item(2) oSketch.Edit() If vValue_Closer = "" Then Dim oLines As SketchLines oLines = oSketch.SketchLines Dim oSelectset As SelectSet oSelectset = _invApp.ActiveDocument.SelectSet oSelectset.Clear() Dim oLine As SketchLine For Each oLine In oLines oSelectset.Select(oLine) oLine.SketchOnly = True Next Else Dim oLines As SketchLines oLines = oSketch.SketchLines Dim oSelectset As SelectSet oSelectset = _invApp.ActiveDocument.SelectSet oSelectset.Clear() Dim oLine As SketchLine For Each oLine In oLines oSelectset.Select(oLine) oLine.SketchOnly = False Next End If oSketch.ExitEdit() End Sub
yuhanzhang wrote:, but for the hatched/filled regions currently there is no APIs to hide them(for filled regions you can either delete them or set the same color as the background, while for the hatched regions currently there is no API to access them).
Can you shed some light on the code required to access the filled regions and change their color? So far I've had no luck.
oSketch.SketchFilledRegions has no 'Color' attribute to set. Only Count, Address, Item, and Type.
and
Dim oSketchFill As SketchFillRegion
oSketchFill.Color = oColor_White
does not want to work either.
Below is VBA code sample, you can have a try:
Sub Sample() Dim oDrawingDoc As DrawingDocument Set oDrawingDoc = ThisApplication.ActiveDocument Dim oSheet As Sheet For Each oSheet In oDrawingDoc.Sheets Dim oSketch As DrawingSketch For Each oSketch In oDrawingDoc.Sheets(1).Sketches Call ChangeFillRegionColorAndHideCurves(oSketch, oDrawingDoc) Next Dim oDrawingView As DrawingView For Each oDrawingView In oSheet.DrawingViews For Each oSketch In oDrawingView.Sketches Call ChangeFillRegionColorAndHideCurves(oSketch, oDrawingDoc) Next Next Next End Sub Sub ChangeFillRegionColorAndHideCurves(oSketch As DrawingSketch, oDrawingDoc As DrawingDocument) Dim oFillRegion As SketchFillRegion, oEntity As SketchEntity oSketch.Edit ' Change the fill region color to be same as sheet color For Each oFillRegion In oSketch.SketchFillRegions oFillRegion.Color = oDrawingDoc.SheetSettings.SheetColor Next ' Set the sketch curves to be visible in sketch mode only For Each oEntity In oSketch.SketchEntities If Not oEntity.Type = kSketchPointObject Then oEntity.SketchOnly = True End If Next oSketch.ExitEdit End Sub
That helps immensely, this has all helped me over a huge hurdle I've been having with my drawings. Thank you so much!
